OD pedal for 'hot rodded' Marshall tone
Started by Crazy_Joe, April 01, 2007, 06:56:46 PM
Crazy_Joe
Ok i am confused as to what to get now. The MXR, the Boss clean boost??!
Black Dogs
^ How about something that does clean boost AND overdrive, like this:
Or this:
(But you would have to get the HBE custom made for you)
Woogie
Get the MXR Zakk.
I use it through a Laney also and it sounds great!
Crazy_Joe
TO those look mightily fine and i would love one that does both!
How much are they?
Black Dogs
the_bleeding
MXR micro amp.
Its just a clean boost.  Place it in the FX loop, or somewher ein the chain and all it will do is make your guitar louder.  PERFECT for solo boosts.
its also super cheap... i can get one in canada for 75$... so that would translate into about 30-40 quid at most.
the zakk wylde pedal is just a microamp with 2 more knobs and a logo on it.  Adds alot to the pricetag... damn endorsements.
Woogie
Crazy_Joe
So by adding 2 pedals it won't get too noisey?
Black Dogs
Woogie
No, aslong as you set the levels sensibly.
I think the micro amp is better for boosting a guitar signal through a long chain of pedals.
Crazy_Joe
So which was for which again?
The Micro amp is the clean boost for solos and the OD pedal is for the general tone that will be on all the time, right?
Black Dogs
Woogie
You can use the OD to vary you tone more. You could put level on 100 and gain on 0 for tightening those lows. You can use it for a boost.
More versatile than a micro amp!
Crazy_Joe
Thing is i want to keep my sound pretty much the same, as i like it though just add more harmonics and for it to sound a little more boosted in general.
Black Dogs
Woogie
MXR Zakk oozes harmonics.
Just turn level up and gain to 0
Kilby
Another option is the marshall bluesbreaker 2, that has clean boost and and crunch modes. Though the Buesbreaker 1 is better
It suits some amps better than others (I preferred it to the Tubescreamer through fender amps), especially through a dirty amp (it even improves the VAT I have lurking)
Best of all it's cheap
The Proco RAT calso works pretty well into a dirty amp
Rob...
Goodbye London !
Crazy_Joe
Cool, i use Marshall FX a lot i have a Jackhammer (which i don't use anymore, in fact it might even work for what i want it to do! ima go try i now :lol:) a Reflector reverb and a Supervibe chorus.
Black Dogs
jesus, how hard is it to just make the right choice and get an SD-1 or a modded SD-1 (zakk, keeley, analogman). To be honest, although i love my clean boost, i don't use it for any 80s rawk other than VERY early def lep, g'n'r, ACDC (more classic rock guitar sounds really).
The sd-1 will add some nice harmonic overdrive to your already overdriven sound and through your laney should be able to make any multitude of 80's rock guitar sounds!
