OD pedal for 'hot rodded' Marshall tone
Started by Crazy_Joe, April 01, 2007, 06:56:46 PM
Crazy_Joe
I decided that my Laney needs a bit more oomph! More harmonics, more life. So i have decided to put an OD pedal in the mix for a good tone boost.
I was looking at the MXR Dist+, it looks like what i want, and should give me a good boost.
Is there anything else that people would recommend for this kind of tone?
Black Dogs
are you gonna be using the pedal to boost an already overdriven amp tone?  if so then I would advise against the dist+, I'm not a fan of it's tone used in that way (goes farty/mushy).
the best pedal for the use you're suggesting is a plain old SD-1 or Tube Screamer.
:twisted:
The MXR Dist+ is VERY similar to the DOD 250 Overdrive that I use.  I'd have a hunt around and see which you can get cheapest.  I got my DOD recently for £23 but they've sold out now  :(
I use mine into a pretty clean amp though, so what HTH says above might be a consideration...
Quote from: TwinfanThe MXR Dist+ is VERY similar to the DOD 250 Overdrive that I use.  I'd have a hunt around and see which you can get cheapest.  I got my DOD recently for £23 but they've sold out now  :(
I do like them into a clean/crunchy amp, but try boosting a 2203 Marshall with a dist+ and it looses focus in the bass end (imo).
Woogie
Randy Rhoads boosts his JMP 2203 with an MXR Distortion+
WITH FULL DISTORTION
I have a Boss Sd-1 SUper Overdrive,from 80´s
made in japan
i think i can part ways with it.
but it´s pretty scratched,cause i got it fromanother person.probably, he´s from 80´s, cause he has 56 years old etc
ahahahahahaha
JP
blatantly get an SD-1 for that kind of tone. Or if you prefer it a wee bit tighter, more midrange (and imo more processed sounding) go for a tubescreamer. Don't even consider anything else.
if you only need a slight boost, clean boosts can be nice.
Woogie
Japanese OD-1 like Jake E Lee, MXR Zakk Wylde (modded SD-1, I own it), Tubescreamer TS808 would be my first choices.
the_bleeding
the mxr distortion plus is a distortion pedal and not an overdrive, instead of adding a gain stage or kicking your preamp section harder, it will actually change the sound.
i'm personally not a fan of boss pedals infront of the amp because they kinda eat tone...
I recommend the maxon OD 808, it can make poop sound good.  In my eyes its the all-star overdrive.
Quote from: indysmithblatantly get an SD-1 for that kind of tone. Or if you prefer it a wee bit tighter, more midrange (and imo more processed sounding) go for a tubescreamer. Don't even consider anything else.
Summed it up.
Alex
I use the SD-1 as well with my Marshall and a Bad Monkey with my 5150. Those combinations work better than vice versa.
horsehead
The bleeding is spot on, the Maxon 808 is absolutely blinding! Keeps your overall tone & add's that lovely harmonic overdrive that you'r looking for. Give them a try...I did & it cost me £125 :lol:
Brow
Depending on what your budget is, I really like a Fulltone Fulldrive II into an overdriven amp.
