Main Menu
speed
Started by Tarzan, April 03, 2007, 12:39:19 PM
Tarzan
can anybody suggest any good exercises to get my picking speed up?
cheers
Sekhmet
Lateral or Horizontal picking?
On Single string runs then you want to concentrate on having the smallest possable pick movement, start of really slow with a metronome and gradually build up speed.
Play in 16ths (4 nothes per click) and accent the first note on every click this will help you build up pick control rather than an uncontrolled spasm.
Then start adding notes in, chromatically is a good place to start, then diatonically.
For across string chops my absolute favourite exercise is the Sailors Horn Pipe Jig, has everything you need, alternate picking, economy picking, intervalic picking and string skipping.
If you can affoard it John Petrucci's Rock Discipline DVD is pretty much the bible of melodic shread.
If not try //www.shredaholic.com for some great shread lessons or //www.wholenote.com for a really detailed site on guitar playing in genral.
One last thing, if you don't have a metronome, get one, it's one of the most important peices of equipment you'l own (although it does have a tendancy to drive people insane).
Jesus was a Thrasher
www.myspace.com/sekhmetuk
Tarzan
thanks for that
would the book be as good as the DVD, or should i spend the little extra?
808
You'll need a metronome if ya get John Petrucci's book or dvd.
It helps out alot having a metronome. You can take a fast lick and with a metronome play it at a slow tempo. Then gradually bumping up the speed on the metronome until you get to the original tempo.
Having a metronome done wonders for me as far as scales, chromatic exercises, and learning licks.
BKP: Aged Nickel Mule set
Tarzan
I've already got a metronome, so that's not a problem.
Love my metronome.
Tis a shame it doesn't go faster than 208 =/
Quote from: noodleplugerineLove my metronome.
You need more tha 208bpm? This I gotta hear!!
Lay some shred on us, son!!
808
That makes 2 of us TO! :)
It's not that - I just feel more comfortable when I play half the speed of a metronome, it's a stupid thing I have, and usually means I end up using my PC and w/e programs I have open to tick for me :p
Muso
The only exercise you need is Tumeni Notes by Steve Morse, strict alternate picking just do the high neoclassical arpeggios then the muted low string arps, in my experience there is no other better picking exercise.
Sekhmet
Quote from: TwilightOdyssey
Hehe it does happen theres a metronome on the wholenote site that goes up to 300bpm but it goes up in intervals of 10 which can be a pig when your really trying to push for those extra notes.
I'm sure there are other portable ones that go to 300 bpm, or download audacity(free) and program in a click on that, you can have it at an tempo you want in any time signature.
I preffer the DVD as it's more in depth and it helps you analyse your playing more but the book would be just as good if your really good at analysing your own technique or you have a good tutor.
I had the Petrucci Chromatic 16th note exercise off the dvd at 208+ was really weird, has a really odd effect on your tone.
Muzzzz
Wha...? The arpeggios in Tumeni Notes are ALTERNATE PICKED??!!? $%&#! (Okay Muz, settle down now..) That's so insane!! But yes, I went to a concert of Steve's and he's most certainly a machine.
{Insert witty signature HERE}
Tarzan
I'll have to wait a while to get the DVD, cause i've got barely any money atm, but it sounds worth it
Sekhmet
Quote from: MuzzzzWha...? The arpeggios in Tumeni Notes are ALTERNATE PICKED??!!? $%&#! (Okay Muz, settle down now..) That's so insane!! But yes, I went to a concert of Steve's and he's most certainly a machine.
It's like the arrpegios at the start of Stevie Via's solo in Crossroads, all alternate picked.
Crazy stuff.
Muzzzz
^ :o  Bloody oath, I thought sweeping them was hard enough.. :oops:
