wtf is making this noise on my guitar?!
Started by _tom_, April 05, 2007, 12:03:28 PM
I think this is the same problem I had beforehand (see the Mule thread somewhere here), kinda sounds like feedback and the sound it makes when you pick behind the nut:
http://download.yousendit.com/210FB8CF63CA4F70
It only seems to happen when I play a D chord, but its so irritating :x Any ideas?
Sounds like something vibrating.  Loose locking nut string tree?  Lose machine head?  Internal wires somewhere vibrating?
Where's the noise coming from acoustically??
I cant really tell where its coming from, its hard to hear unless I'm plugged in.
I'll have to stuff the springs with kitchen towel, tighten everything and try again I guess. Someone on HC said it could be a badly cut nut, is that possibly the problem?
Scum on the nut saddle might do it, yep.
I have been using graphite from a pencil in the slots to make it all smoother, just cleaned it out and there was no difference. Very annoying, I might have to take it to a tech if stuffing the springs wont work :?
Have you cleaned the bridge saddles too?
gingataff
Tremolo springs I reckon.
Jam some cotton wool and toilet paper between them and see if that helps.
EDIT: Oops, looks like you've already mentioned it twice above! That'll teach me for not reading the full thread.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Don't know if it would work as well on a Strat trem, but I greased the springs on my Kahler years ago and it totally cured the creaking.
Could be messy if you're a no-backplate kinda guy, of course.  :?
gingataff
Trem springs often vibrate just like a spring reverb and sometimes they have more of a ring to them. I think the springs on my Schaller bridge are less 'ringy' than some of the Japanese (Gotoh?) bridges I have so maybe try some of those. Another thing I've done is put duct/duck/gaffa tape across the springs, it seems to absorb the vibrations without altering tone and doesn't stop you using the bridge but does someimes get unstuck ;)
Even guitar heroes suffer from this: http://www.vai.com/Machines/guitars1.html click on All about Evo and then click on Body (Back)
And I'm coming home
Sounds like I've sorted it! Stuffed the springs with kitchen towel then held it all together with duct tape.. course its pretty much impossible to use the trem now, but I never used it beforehand anyway ;) I might try some Schaller springs if I can find any (any idea where to get em from?), then see if I can get the bridge set up to fuction as a proper trem with no squeaks! It all seems to stay in tune now for some reason, before I stuffed it I was having problems keeping it in!
Thanks for the replies :)
gingataff
I think Feline may be able to help you out with Schaller springs but don't quote me on that.
And I'm coming home
Yep - we have some Schaller springs
About £9 for 3 of them
I favour them over all others myself
They may need to be stretched out a bit more than ssome of the other brands but that is a good thing as they are under tension even when the whole system is balanced (not in dive bomb mode)
I recommend 2 springs for 9-42 (sometimes will work for 9-46)
The claw will need to be screwed almost all the way back but it works!
3 for 10-46 (or 9-46 as well)
I also angle the two outer springs - wide at the sustain block (holes 1 & 5) and narrow at the claw (hooks 2 & 4)
Mavet
I used to have the same problem. It came from behind the nut (I have a locking nut).
Try to pick the strings behind the nut while plugged in to see if its that.
I used a very thick piece of felt under the strings there to sort it.
Quote from: FELINEGUITARSYep - we have some Schaller springs
Cheers Jonathan, I did email you but seems like you've answered my question here - how do I go about ordering a set of 3?
Gimme a shout in the workshop on Tuesday
Sorry for the delay with the email
Been so up to my neck with LGS preperation
