Quick question
Started by BloodMountain, April 06, 2007, 01:33:56 PM
BloodMountain
is there really a V30 in here or is it just a Marshall Vintage speaker?
he says it's a V30, but it doesn't say that on the speaker......
http://cgi.ebay.co.uk/Marshall-TSL-2x12-Extension-Guitar-Speaker-Cab_W0QQitemZ270105990185QQcategoryZ10171QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
cheers, BM  :twisted:
It's the original version that was in the Silver Jubilee - they just say Vintage on them.
BloodMountain
Quote from: PhilKingIt's the original version that was in the Silver Jubilee - they just say Vintage on them.
so they'll give the same sound as the V30s?
Celestions are renamed when they're shipped to Marshall.
BloodMountain
i have another question... is it a good idea to use this 16 Ohm cab with my 4 Ohm guitar head?
BloodMountain
Quote from: BLOODMOUNTAINi have another question... is it a good idea to use this 16 Ohm cab with my 4 Ohm guitar head?
Yep, that's a Vintage 30 and a G12H.
Is your head solid state?  If so, this cab will be fine but will reduce power output.
If it's valve, I wouldn't run such a large mis-match of impedences.
BloodMountain
it is hybrid, but only has one valve in the preamp.
and that only comes on when using OD channels...
so it will be fine?
What is the head?   If it is a transistor one, it will just be quiter, as it will reduce the output by 75%!  On a valve amp, you should be able to set the impedence.
You can also wire a 2x12 16ohm cab to 4 ohm by making the wiring parallel instead of series (as there will be two 8ohm speakers).
BloodMountain
see here:
Quote from: BLOODMOUNTAINit is hybrid, but only has one valve in the preamp.
so it will be fine?
EDIT: thanks for the info on the wiring thing  :twisted:
Yep, you'll be fine with your head with that cab, but even better if you re-wire it to 4ohms (easy enough to do).
BloodMountain
Quote from: TwinfanYep, you'll be fine with your head with that cab, but even better if you re-wire it to 4ohms (easy enough to do).
heh, that cab finished last night, i missed it by about 5 minutes  :evil:
yeah, i am going to rewire it if the one i get is 16Ohms.
That cab went CHEAP  :o
BloodMountain
i know, i can't bloody believe it!
my dad was spouting bullshitee an hour before it ended, like "how can you trust it, the speakers may be blown" and "that's a lot of money for a cab".
he pisses me off.
He's your Dad-thats his job.
