Author Topic: Wiring experts:Prs wiring  (Read 7549 times)
viking
« on: April 22, 2007, 04:21:46 PM »
My custom22 has a 5way rotary switch;i would like to have the 2 humbuckers together but the normal wiring don't give you that !How can i do it ? The rotary switch is a special Prs switch (pcb?).I really don't understand why they don't do it !I like the 5 combinations but i would like to hear my new Mules together ! :?
froglord
« Reply #1 on: April 22, 2007, 04:52:22 PM »
I can't answer your question, but a good place to start would be the PRS wiring diagram:
http://guitarelectronics.com/product/WDUHH5R1101
Somehow, you have to figure out what's happening circuit-wise, then re-wire it to give both humbuckers in parallel.
FWIW, the Mules in my Eggle (which is like a PRS but a bit lighter) sound great in the middle position.
Egnater Tweaker 15
« Reply #2 on: April 22, 2007, 06:25:19 PM »
If you look up the original PRS 5-way wiring you will find that it does give you both pickups in position 3.  You lose some of the other settings too though.
viking
« Reply #3 on: April 22, 2007, 08:32:26 PM »
Thanks for the help !I really wonder why Prs did change the 3° position  ( in 1989),it's a good sound but i'd rather have the 2 humbuckers together...
viking
« Reply #4 on: April 25, 2007, 01:57:06 AM »
If i understand correctly,the 3° position is the 4coils together(série),so it's the 2 humbuckers together !So...no problem! :D
« Reply #5 on: April 26, 2007, 11:29:19 AM »
Quote from: viking
Not since the early 90's.  The 5 positions are:
Bridge
Bridge and Neck Screw Coils Parallel
Bridge and Neck Screw Coils Series
Bridge and Neck Slug Coils Parallel
Neck
This doesn't give the 2 humbuckers, just a wide humbucker from the series setting in the middle postion.
viking
« Reply #6 on: April 26, 2007, 12:29:41 PM »
That's what i had understood but ,since i wanted the 2 humbuckers together...,my guitar-tec finally told me the 3°=4coils/série  :x .How can you have those 2 humbuckers together?!!!!!! :?:  :?  :x                             PS:Phil,it seems you have most BNP,could you describe the difference between the Mule (i now have a set ) and Black Dog,Abraxas,Emerald and VH2 ?Would be nice  8) .
« Reply #7 on: April 26, 2007, 12:45:36 PM »
You have to use this wiring:
http://www.prsguitars.com/csc/schematics/5wayrotary_85_89.gif
But you lose some of the other in-between positions.   Your tech has to rewire the switch itself for this.
viking
« Reply #8 on: April 26, 2007, 01:10:27 PM »
It seems to be too difficult for him... :(
