Author Topic: Matamp users  (Read 23982 times)
  • Truly bad since 1972
Matamp users
« on: April 22, 2007, 11:28:04 PM »
Likeing the look of these but still unsure so can you help me out..give me rough idea what you have and what sound you use them for..thanks
what model and cab(speakers) do you have
what music you playing
Matamp users
« Reply #1 on: April 23, 2007, 10:14:59 PM »
anyone?
horsehead
Matamp users
« Reply #2 on: April 24, 2007, 09:04:47 AM »
apparently no one!
froglord
Matamp users
« Reply #3 on: April 24, 2007, 09:48:16 AM »
I held off on this topic for a while because I've only got the low-wattage Minimat (the version with the 6v6 rather than the EL84). It goes into a 1x12 with a Celestion Alnico Blue.
To get higher gain you need a couple of pedals, but the Minimat takes pedals very well. I also find it's a bit light on the treble, even with the Tone at full. To fix this I use an Xotic RC booster (which doubles as a boost to push the valves harder) and it's a marriage made in heaven. As a low-volume bedroom/lounge setup, the Minimat and RC is the best combination I've ever heard.
I play everything from ultra-clean up to hard rock. The only thing I wouldn't recommend the Mini for is metal (just hasn't got that hard edge).
While visiting the factory I also had a good go on the First Lady and heard another guy ripping merry hell on a 1224. The First Lady is like the Minimat, but louder, with no attenuator, more EQ controls and switchable output valves. The other valve (a 6CA7, similar to an EL34) gives more gain, more treble and sounds more Marshall-esque. The 1224 is a tone monster of epic proportions.
In general, I'd describe the Matamp tone as exceptionally clear and crisp with huge weight. You can't hide bad technique because you can hear everything. Incidentally, they're tested and voiced with BKPs (although that may have changed now that their chief player has started his own pickup company).
Egnater Tweaker 15
Rob Stobbs
    • http://www.sonoma.co.uk
Matamp users
« Reply #4 on: April 24, 2007, 11:06:25 AM »
Sorry Guys, Only just found this topic, still recovering from a very eventful night on another Forum that I frequent. Means I'll be spending MUCH more time here from now on. :lol:
OK: Over the years I have (more or less) used Matamps exclusively and feel very fortunate that I found them as early on as I did. It certainly saved me considerable time and effort, not to mention MONEY.
Overall, the range has changed beyond belief over the last 10 years or so, BUT always for The Good.
Froglord is quite correct in saying that THE Matamp Sound is Crisp and Clear.
But do not let that mislead you! We are talking about an almost "Hi-Fi" Quality to the sound, which is hardly surprising when one considers Matamps Origins.
They have the same "Open" Sound that one so often hears when people are attempting to describe a Bare Knuckle Pickup. This means that the "definition" of Each Note is still there, No Matter What you are using in the way of Boosts etc, or, come to that if you are running your Matamp at pretty near Meltdown!
A perfect example (In Layman's Terms) would be a comment I heard made by a Good Friend of mine recently.....He is a very recent convert to The School of Matamp by the way. He said, " Marshall's Shout, Fender's Spit and Snarl whilst Matamp's Purr." He was a longtime Marshall and Fender Guy who has literally had his whole thinking changed by the arrival of my Matamp C7 Head and Alnico Blue Loaded 1X12. I sent it over to him in Canada with all manner of different Valves to try and he is HOOKED.
As Froglord said, It isn't unusual to use a Pedal or two with a Matamp, mainly because they do have Tremendous Headroom and things do get a bit loud....or can do.
The Mini Mat has been spoken about, as has the "First Lady" (The Successor to the C7). The Range can accomodate just about every player's desires as far as Wattage is concerned. The King Street is an absolutely Out Standing Amp, gaining Huge Popularity and about to make another Big Leap as The King Street Major finally becomes a regular part of the Line.
The 1224. What's left to be said about this amp? It has fast become probably the Biggest Seller in The Range. I'd guess that the most current versions have to be one of the most Flexible Amps around. I had one of the very First Ones and thought it to be wonderful, BUT, because I am a Sad Old Git and getting on in Years....I preferred the V28, which was a Rather more Simple equivalent. It did not share the Switching Facilities of the 1224, but the SOUND!!!!! Oh My Lord....That Sound!
I have a GT1 which has been modded to meet my personal requirements and I have covered this elsewhere so rather than repeat all that I'd suggest you take a look in other threads here in the Amp Section?
Right: I play mainly Blues and Blues Rock with the occasional foray into Country Picking. The GT1 can handle any of these with absolutely No Problem. The Blues styles that I tend to use are similar to Mick Abrahams (Blodwyn Pig & Jethro Tull)  Rory Gallagher, Clapton, Roy Buchanon and of course Peter Green.
Rock would be Wishbone Ash, Floyd, Skynyrd, Early ZZ Top, Kansas, EARLY Whitesnake, Camel, etc. So I tend to use a sound that is basically "fairly" clean, by which I mean it isn't drenched in Gain. My All Time Favourite Guitar Sound has been Andy Powell of Wishbone Ash, so the GT1 was a No Brainer as the vehicle with which to start? Then I can go through to a Dirtier Sound just by Hitting a Switch. Thanks again to Dave Green's understanding of exactly what I wanted to achieve I can cover just about ANY of the above without even thinking about any Stomp Boxes.
You want to get Dirtier? NO Problem. Using a Modded TS9 I can go straight into (shudders) Guns and Roses etc.
I run my GT1 through a 2X12 loaded with Celestion Hot 100s. These Speakers would NOT be my recommendation if say you permenently want to be doing a more Rock Flavoured thing, but for what I do and what I want, they are tremendous. I really thought that I'd have Alnico Blues again until I spoke to Dave and Jeff and they steered me to the Hot 100s and I am delighted.
Again.....As Froglord does, I use an RC Booster, which is Permenantly "On" no matter what Amp I have. Ever since this Pedal became available it has been my "Must Have" part of my sound. I gather that I use mine in a slightly different way to some in as much as I use mine as a Clean Boost.
Back in the early 70's through to the Mid 80's I was Gigging all over Europe using 2.....Yes 2 Matamp 120 Heads into Four 4X12s!!!!!!!!!!
Overkill or what? LOL BUT, They Never Broke Down, they ALWAYS sounded Great no matter where we were Gigging and My Lord....They were Loud. We were at that time becoming The Most Forgotten about Band in the so called "New Wave of British Heavy Rock" and supported countless Name Bands, My Matamps always were sought after by the Name Bands Guitarists and they were always wanting to use My Rig for their Set.
OK, enough! I LOVE em....But you have gathered that?
There isn't anywhere that I am aware of that can offer the Service that Matamp do. Where can you go and just say I want the Amp to Do This and That, Have this feature or whatever, and then get it at a Highly Affordable Price?
Cheer's
Rob
Matamp users
« Reply #5 on: April 24, 2007, 11:12:29 AM »
i use my 6V6 minimat for anything warm and bluesy - sounds great with a tubescreamer up front; gets suprisingly close SRV sounds i find. 8)
Very detailed and clear sound with a les paul that you'll love if yu like an honest tone, but it really won't hide your mistakes. I'd say pedals are pretty much a must
Matamp users
« Reply #6 on: April 24, 2007, 11:48:31 AM »
thanks for replys....am unsure now to go for minimat, firstlady or xv...maby in chino form with one of the celstion speakers.....damn this is hard work..am going to have to visit factory....leave cards at home(or else will buy gt1..and can't afford it)..come away and make decision
rahnooo
    • Over the Wireless
Matamp users
« Reply #7 on: April 24, 2007, 12:00:19 PM »
I know the 6V6 Minimat has been talked about in this thread already, but don't forget there is also an El84 flavour of the same amp. I did a head to head review of both models in this thread here, if you want to know the differences:
http://www.bareknucklepickups.co.uk/forum/viewtopic.php?t=5196&highlight=
*Rahnooo*
Mules
Blackguard '55 Staggered
Matamp El84 Minimat.
Matamp users
« Reply #8 on: April 24, 2007, 12:23:57 PM »
got to love this forum....if you ain't tried it someone else has....thanks for replys..am wavering minimat(unsure on valves), first lady, xv...then so many choices for pseakers..ahhh
Matamp users
« Reply #9 on: April 24, 2007, 01:18:52 PM »
Ihave the 6V6 version of the MiniMat and find it great for classic rock and blues into heavy rock.  I have a lot of amps so comparing it is relatively easy.  I use it with a Heritage G12M (20watt version), in the slope front Matamp 1x12 (both amp and cab are covered in red with black fronts).  I found the MiniMat to be critical of the speakers that you use, which isn't a problem if you go visit Matamp, because they have 10 different speakers set up for you to test with.  Overall I liked the Celestion Blue the best, but the G12M was a near second and a lot less money, though if I was getting a bottom cab (which I well might!), I would put a G12H in that.
This is a picture along with my Silver Jubilee and Ear Candy extension cab (both with Celestion Sidewinders).
Matamp users
« Reply #10 on: April 24, 2007, 02:11:35 PM »
have a marshall heritage loaded cab...similar to the one twin fan is selling is matching cab to my marshall jtm30
Tricalibur
    • artistsofwar.net
Matamp users
« Reply #11 on: April 24, 2007, 03:28:14 PM »
Ill be getting a coustom 150 watt GTL someday :]. I did the little price qoute thing on their website and with all the features i wanted the total cost came to around 6000 American dollars (about 3120 British pounds).
<The Warpigs Are Coming, Hide your Children... and bring BBQ Sauce>
froglord
Matamp users
« Reply #12 on: April 24, 2007, 04:20:43 PM »
sgmypod, if you're looking at the Minimat, you might be interested that they seem to be working on a Minimat II:
http://p203.ezboard.com/Whats-new-in-Minimat-mkII/fofficialmatampownersclubfrm19.showMessage?topicID=228.topic
This might be the "secret" thing they're going to debut at the London Guitar Show.
There are some Minimat sound clips (6V6 and EL84) here:
http://www.matamp.co.nz/soundclipsmatampminimat.htm
Egnater Tweaker 15
Matamp users
« Reply #13 on: April 24, 2007, 04:23:58 PM »
yeah read that somewhere, am holding on for a little while until get enough cash together...so not choosing because of price
have two amps at mo a jtm30 and cab(resideing at my friends need to sell that)
and an atomic.(is a like a power amp and cab..valve all in one for my podxt, has # 2 x Premium JJ EL84s power tubes # 1 x 12AX7A tube (phase inverter)) ain't bad...but am hankering after a matamp, maybe keep podxt for verbs etc
horsehead
Matamp users
« Reply #14 on: April 24, 2007, 06:56:46 PM »
that's it...I can't take it! I was gonna get a Cornford Hellcat, but you guys have sent me over the edge...I'm getting a King Street classic...ummmmm tasty
