Is this wiring configuration possible?
Started by Mr Ed, April 24, 2007, 03:50:42 PM
Mr Ed
Nothing radically different, but assuming a regular Strat setup of three singlecoil pickups, a 5-way switch and the usual 1V/2T controls:
Position 1: Bridge
Position 2: Bridge + Middle
Position 3: Bridge + Neck
Position 4: Neck + Middle
Position 5: Neck
See, nothing major... just that position 3 is both the bridge and neck instead of the middle.
Cheers chaps and chapesses.
er unsure put a switch on mine to get that
Mr Ed
Quote from: sgmypoder unsure put a switch on mine to get that
Aahh, so your 5-way just does the usual and then you have a spearate little toggleswitch or something?
I don't think you can do that with a regular five way and single pickup leads.  You'd need to split your middle pickup lead with a 'Y' piece or similar I think?
yeah just an on/off so can have
position 1:Bridge
position 2:Bridge + Middle
position 3:Middle
position 4:middle + Neck (or all three with switch)
position 5:Neck (or with switch neck and bridge)
can't remember why didn't do other way around..but works for me
As an alternative to an extra mini-switch, you could replace one of the pots with a push/pull pot which you can use to add the bridge (or neck) pickup to whatever's selected on the 5-way switch.
So as sgmypod said, you get 7 selections, the 5 standard ones plus bridge+neck, or all 3.
http://www.seymourduncan.com/support/schematics/switch_f_bp.html
true was going to use one but had hole from where I had previously had a split/phase/parallel switch(when it was a HSS, now a all single guitar)
The megaswitch E model gives that exact wiring.  It is made by Schaller, Stewart MacDonald sell it in the US.
