Author Topic: A Mississippi Queen problem - P-90 question?  (Read 9629 times)
  • Truly bad since 1972
« Reply #15 on: May 01, 2007, 01:29:22 PM »
original hiwatts are sweet amps...had a 70's 50 watt head and 4x12 cab wortst mistake I made was selling it
chrisheyes
« Reply #16 on: May 01, 2007, 01:37:35 PM »
You had a go with my Tokai Les Paul Special with the BKP-92 in the bridge and that was to your taste ! The one with ssssssssssssssuuuuuuuuuuusssssssssssssssssttttttttttttttttttttaaaaaaaaaaaaaiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiinnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn !!
I had problems with it initially as the volume was very lowcompared to the neck pickup. After raising the pickup in the cavity and also the polepieces I finally got the match. I have to turn the tone down on it
What value pots have you got - the higher the value the more treble you will get - should be 500K
I've put a hybrid P90 in a Tele at the bridge - This certainly gives power to the people !!!!
Chris
« Reply #17 on: May 01, 2007, 02:05:24 PM »
Cheers Chris, I remember your guitar  ;)
You've got a P-92 though, the MQ is a P-90.  I think I'm using too much gain with it and I reckon it'd sound much better a bit cleaner.  I'm going to try it through a Klipp tonight with my DOD 250 overdrive.
chrisheyes
« Reply #18 on: May 01, 2007, 02:22:53 PM »
Hope you find the tones that's in your head Dave
The BKP92 should have less hi's than the MQ which is why I think the pots may be the problem. Are yours 300k not 500k ?
« Reply #19 on: May 01, 2007, 03:02:41 PM »
Not sure - they're regular Gordon Smith pots.  I'm pretty sure they're 500k as the GS you now have with a Mule and standard pots sounded great!
« Reply #20 on: May 01, 2007, 05:47:14 PM »
Quote from: Philly Q
No, it was aimed at Twinfan (well, in sarcasm terms it was aimed at myself - I've been known to buy then sell guitars without ever having changed the strings....).
But if the cap fits, Dave...  :lol:
oh, is twinfan called dave too? sorry! :oops:
:drink:
« Reply #21 on: May 01, 2007, 10:12:49 PM »
Quote from: dave_mc
He is  ;)
