Author Topic: Under-used Les Paul tones VIDEOS!  (Read 11853 times)
Dane
« Reply #15 on: May 03, 2007, 12:42:53 PM »
Sori Triple post
Dane
« Reply #16 on: May 03, 2007, 12:43:21 PM »
Sori Triple post
Canadian Steve
« Reply #17 on: May 03, 2007, 01:02:35 PM »
Quote from: Dane
Well check this out. An explanation by the man himself of the woman tone. Towards the middle of the video around 1.53. Enjoy 8)
http://www.youtube.com/watch?v=rq6r23-le5o
Very Spinal Tap!  It took a lot of power to turn that wah pedal on!
BKPS: Cryogenic Apache set, Mule set, Riff Raff, Stormy Monday.
apmaman
« Reply #18 on: May 03, 2007, 05:17:45 PM »
is there any way to wire up a LP without adding extra swtiches or changing pots and still get the out pf phase sound? I would prefer not having to change out pots or add switches...
Ive never used a push pull top so i dont know how they work so i will ask this (noob question!) Do they still work as the tone knob? say i was to take out the neck pup tone knob, replace it with a push pull one will it still act as a normal tone pot but if pulled up make the pup go out of phase?
Hope Ive made that easy to understand... :?
Epiphone LP with a BlackDog
« Reply #19 on: May 03, 2007, 05:35:08 PM »
Quote from: apmaman
If your pickups have 4-conductor cable, to put them out of phase all you have to do is reverse the wiring of one of the pickups - e.g. with a BKP swap the red and black wires so black is "hot" and red goes to ground.
If you have 2-conductor braided cable, you'd need to dismantle the pickup and flip the magnet to achieve the same effect.
Quote
Yes, just think of the push-pull as if it's two separate components - a pot and a DPDT switch.  They're completely independent.
5F6-A
« Reply #20 on: May 03, 2007, 06:40:19 PM »
Great Dane.
Thanks a lot!
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
Dane
« Reply #21 on: May 05, 2007, 12:56:50 PM »
No problem man. Still waiting for my mule set. Should be in any moment now. Then maybe i can get better woman tone. 8)
5F6-A
« Reply #22 on: May 05, 2007, 05:59:38 PM »
cheers!
5F6-A
« Reply #23 on: May 05, 2007, 06:00:00 PM »
I've had Stormy Mondays and PGs and both are terrfic old fashioned humbuckers. Mules are great as well.
Dane
« Reply #24 on: May 05, 2007, 07:07:54 PM »
Well i fell in love with mule when i heard them. But to bad i do not have the money to invest in a tube amp. I am still saving. I am only using a peavey bandit which is decent but not phenomenal. Thinking of getting a laney LC15. But do not know if it tak pedals well.
5F6-A
« Reply #25 on: July 18, 2007, 09:27:52 AM »
the most incredible thing is that later on i discovered that the speaker was damaged so the tone wasn't as good as it should have been!!
LOL!!!
JamesHealey
« Reply #26 on: July 18, 2007, 10:57:24 AM »
woman tone = mud
out of phase = horrible
Neither tones i'd ever want to go near, but I understand what musical purpose they serve and the influence they've had through out history im good friends with the lead guitarist of "Green Mac" the Fleetwood Mac tribute band.. So im used to hearing out of phase :P
5F6-A
« Reply #27 on: July 19, 2007, 07:21:00 PM »
Quote from: JamesHealey
woman tone = mud
thanks for your opinion... any videos of green mac?
