P90s in P100 cavity?
Started by tav, July 14, 2005, 02:12:10 PM
tav
I'm not sure of the different pickup dimensions, so I was just wondering if I could retrofit BKP P90's (or any P90 I guess) in a stacked P90 cavity. Would I need maybe some rubber or foam to boost the height of the P90s?
Thanks, tav
Skybone
I'm guessing that if you have P100's, you should be able to fit any after-market P90 style pickup.
Visually, to me anyway, the P100's I've seen look identical to the P90.
Bibble.
tav
Thanks for the reply. I was wondering about the depth, since the P100s have 2 stacked coils.
Skybone
I would again guess at the depths of the pickup hole being the same, as P100 equipped guitars also seem to have P90 equipped variants.
Bibble.
