braided 2 conductor
Started by Devon8822, May 04, 2007, 09:07:54 PM
Devon8822
are there any advantages of choosing 2 conductor braided... ovver 4 conductor? or is it just for the people who want PAF replicas?? Im taking a guess that old PAFs only had 2 wires? thanks
Davey
with 4 conductor wire, you can wire the pickup differently.
in series (how a humbucker is normally wired)
in parallel (still works as a humbucker, but changes the sound and lowers the output)
split (only one coil is active at a time.. you can also chose which one, depending on which wires you solder)
Devon8822
Thanks Davey, I already knew that! lol, im juust wondering if there are any advantages of choose 2. Like whats the point of having 2 availbale if you can just get 4 with all possible options, you know?
Davey
vintage specs.
no other reason i can think of
the wire on 2-conductor briaded is thicker and therefore a stronger connection - the 4-conductor wire is pretty thin.
saying that, I've never had a guitar where the wire has snapped with 4-conductor wire.
:twisted:
BloodMountain
2 conductor is simpler  :twisted:
Quote from: BLOODMOUNTAIN2 conductor is simpler  :twisted:
lmao, I suppose it's three less wires to deal with.
:twisted:
Devon8822
If i want to just use 2 wires can I just buy a 4 wire one and than not hook up the other two? or if i get a 4 wire one, do i have to hook up all of them. Dumb question Im expecting to hear that I can do that, although I better make sure before i get into trouble. :)
Yes, you can buy 4 conductor and only use 2 of them.  The green/white should then be joined together and sealed.
Crazy_Joe
Haha i always buy 4 conductor now, i think it's easier and quicker than 2 conductor because you have to peel back all the braided cr@p before you can solder in.
Black Dogs
Bird
I've done one of each and I'll be sticking with 2 conductor from now on... so much easier for me  8)
