Author Topic: distortion  (Read 4781 times)
CaffeineJunkie
distortion
« on: May 08, 2007, 09:56:43 PM »
how would you put distortion on a voice clip or from a microphone??
Cheers
James
distortion
« Reply #1 on: May 08, 2007, 09:58:48 PM »
You will need a plug in to run the waveform through.
CaffeineJunkie
distortion
« Reply #2 on: May 08, 2007, 10:01:43 PM »
....from the mic??? does that mean i can't run it through a standard guitar fx pedal??
what bout if i wanted to add some after it's been recorded??
distortion
« Reply #3 on: May 08, 2007, 10:58:22 PM »
Hmm, if you want to distort the mic's signal before you record, you need to run it this way:
MIC > MIC PRE > LINE OUT ... DISORTION EFFECT > LINE IN
Afterwards you need to use a computer plug in.
CaffeineJunkie
distortion
« Reply #4 on: May 08, 2007, 10:59:43 PM »
hmmm... kool
sounds like a bit of a plan then... cheers
James
Kilby
distortion
« Reply #5 on: May 09, 2007, 12:57:13 AM »
Trash is pretty good for that sort of thing I think it has both telephone and loudhailer distortion presets http://www.izotope.com/products/audio/trash/
Goodbye London !
CaffeineJunkie
distortion
« Reply #6 on: May 09, 2007, 01:00:49 AM »
that trash program looks pretty kool... shame about the price tag, but i'm sure i can find a way around that ;)
distortion
« Reply #7 on: May 09, 2007, 04:37:09 AM »
Combine bandpass fillter and drive stage, otherwise it will be too fizzy or boomy, the bandpass will only let mids through. You could also experiement with a sweep.
Try plugins but also try outboard FX (e.g. run mic through a Wah into an overdrive or Fuzz or even just a cranked gain stage of a mic pre or mixer channel - my mackie is clipping very nicely actually).
There also used to be a great preset for that clipping radio voice stuff in my old SE70 for that ... in case you know anyone who's got that unit.
