Author Topic: Fender prosonic  (Read 6600 times)
  • Truly bad since 1972
Fender prosonic
« on: May 12, 2007, 06:52:54 PM »
Seen one of these with celestion 2x10 v30 speakers...anyone no much about them
aj_gibbo
RE: Prosonic
« Reply #1 on: May 12, 2007, 07:17:20 PM »
I own a Fender Prosonic and it divides my opinion at times! It's got a really good clean sound (very dark and fat for a Fender), and an almost Mesa Boogie like lead channel. Sometimes I love it, and other times I think it's got almost too much gain, but I do love the cleans on it. It's also really loud for it's size, and has the versatility to operate in pure class A with a valve rectifier, class A/B with a valve rectifier, or class A/B solid state rectifier (for the most clean headroom).
All in all a really good amp, but it has to be what you're looking for - it's not a typical Fender sound.
Fender prosonic
« Reply #2 on: May 12, 2007, 07:18:47 PM »
yeah been trying it against the hot rod junior and the hot rod deluxe
Fender prosonic
« Reply #3 on: May 12, 2007, 07:22:15 PM »
am very tempted
aj_gibbo
Fender prosonic
« Reply #4 on: May 12, 2007, 07:38:40 PM »
Personally I think it's a much better amp than the hot rod junior or deluxe. Mine cost about £900 when new, so they should be the next step up! How much is this one going for?
Fender prosonic
« Reply #5 on: May 12, 2007, 07:50:44 PM »
in perfect nick with pedal etc, made in 1996 says custom shop
Elliot
Fender prosonic
« Reply #6 on: May 13, 2007, 12:40:22 PM »
Get it - its a bargain, its a great amp and its one of those amps that will be worth loads in the future as it is highly desirable.
aj_gibbo
RE: Prosonic
« Reply #7 on: May 13, 2007, 01:22:48 PM »
For that price I'd definitely go for it! It's a really well built amp, and has great tone!
When they come up on E-bay (which isn't that often) they usually go for around the £500-£600 mark so definitely go for it!
Fender prosonic
« Reply #8 on: May 13, 2007, 02:28:27 PM »
thanks think I will only problem it has is the switch noise when changing channels..been reading and is a inherant problem that a mod can fix
Fender prosonic
« Reply #9 on: May 13, 2007, 07:13:22 PM »
what tubes you got in yours aj and any problems other than identity crisis(fender mesa)
aj_gibbo
RE: Prosonic
« Reply #10 on: May 13, 2007, 08:38:25 PM »
Hm, not 100% sure what valves I have in there at the moment! I asked Watford Valves what they would recommend and I went with their recommendation. I think it's got Harma 6l6GC's, a Philips 12at7, and Sovtek EH12ax7's. I think the valve rectifier is also a Harma branded model GZ34.
The only problem (if you can call it that) is the lead channel. I love the clean sounds, and the lead channel depends on what mood I'm in. If I want heavy rock or a bit of metal then it's really good, but if I just fancy a bluesy or Fender style overdrive then it's not that great. I tend to use the clean channel now and either add a tubescreamer for overdrive, or switch to the lead channel on a really low setting (gain at no more than 3-4) and add an overdrive pedal to taste.
You also have to remember the eq section is active and doesn't work in the normal passive way that most amps do. It takes some getting used to, but once you find a sound you like it sounds pretty damn good.
Check this out for further reading
http://en.wikipedia.org/wiki/Fender_Prosonic
Fender prosonic
« Reply #11 on: May 13, 2007, 08:41:10 PM »
did you put in own valves, did it need biasing and how much(any difference to sound..cleaner etc...or buzzing etc)
aj_gibbo
Fender prosonic
« Reply #12 on: May 13, 2007, 08:48:21 PM »
I put the valves in myself. I was told it wouldn't need re-biasing, but I'm still not sure about that, lol! I should really get it serviced soon so maybe they can have a look then.
I noticed after changing valves that there was definitely more clean headroom, and more of a bitting sound to the distortion. It was really high gain before, but lacked bite. Once the valves were changed it definitely added an edge to the tone (in a good way)....if that makes sense?
Fender prosonic
« Reply #13 on: May 13, 2007, 08:52:28 PM »
how much it cost?
