Author Topic: Valves Help  (Read 3499 times)
  • Truly bad since 1972
Valves Help
« on: May 17, 2007, 12:19:30 PM »
Long time since looked into valves have just bought a Fender prosonic..nothing wrong as far as I know with the valves...but for future reference would it be worth changing any of these
mine has chelmer premium gz34, 5881wxt x2, fender 12ax7a's x3 then sovtec 7025, fender12ax7a, sovtec 7025 so odd mix I guess
Fourth Feline
Re: Valves Help
« Reply #1 on: May 17, 2007, 03:10:21 PM »
Quote from: sgmypod
I have a Fender 'Evil' Twin and found the following:
The Fender 12ax7s tend to be re-badged Sovtec 7025s anyway. The better sounding alternatives ( clear with big sound stage ) were JAN/Phillips 12AX7s   from Watford Valves. If you like lower gain, but more detail, substitute Valve 1 with a Jan/Philips 5751. ( Stevie Ray Vaughan replaced all his pre amp valves with 5751s ).
For outputs, I prefer 7581a types. These Bias like a 5881/6L6 but tend to give  a big clean sound.
If you like early breakup and more compression, use N.O.S. short base 6L6WGB  types. You will therefore benefit from some 'Harma' hot graded 12AX7 pre amp tubes from Watford valves or near offer.
I do not work for Watford valves - but they do seem to be the 'BKP' of valve selection. The website, or the owner ( Derek ) also can advise according to your tonal tastes.
Happy tone hunting !
F.F.
Hell Hound
Valves Help
« Reply #2 on: May 17, 2007, 03:16:18 PM »
I  can't agree more, Watford Valves know their business. I'm GASing for some of their cryo valves as they get raves review: "almost like NOS"
Valves Help
« Reply #3 on: May 18, 2007, 02:34:34 PM »
thanks for reply am a bit dumb with valves....been a while since changed any or owned a full valve amp
JamesHealey
Valves Help
« Reply #4 on: May 18, 2007, 04:59:13 PM »
if u like the sound of it dont change the valves..
tbh, a lot of people mix and match valves to find the best tone..
u might find if u stick all one brand in it loses some of that magic
for instance my splawn is like
V1, Sovtek 12AX7WB
V2, Sovtek 12AX7WC
V2, Sovtek 12AX7WA
2x New Sensor Mullard EL34s biased at 70%.
which is quite different to how mr splawn ships them.
Valves Help
« Reply #5 on: May 18, 2007, 08:00:04 PM »
what splawn you got and where from ?
