Author Topic: H-S-H & std 5-way switch  (Read 5120 times)
Antag
« on: May 23, 2007, 02:55:02 PM »
Is it possible to get the following combination for an HSH pickup config with the std 5-way switch, or would I need the megaswitch?:
1 - Bridge hum
2 - Bridge hum + Mid single
3 - Mid single
4 - Neck split + Mid single
5 - Neck hum
I'm guessing #4 is the showstopper, although you can supposedly get Bridge split + Mid single on #2 so why not #4?
« Reply #1 on: May 23, 2007, 11:14:58 PM »
Depends on the number of tabs, a lot of 5 way switches only have 3 tabs and the common.  With that there is no way to get what you want.  If you can find one with 5 tabs and the common, then you can do it.
Bird
« Reply #2 on: May 24, 2007, 04:40:01 AM »
That's how I've got my RT wired up. I think I got the 5 way from BKP.  8)
« Reply #3 on: May 24, 2007, 09:29:11 AM »
yes - thats an easy one George
It's like the Jem wiring but without th coil split on the humbucker in position 2
Use one of the variants of the Jem wiring but dont attach the series link of the bridge HB to the switch (just tape it off)
