Wich pickup for a real heavy sound?
Started by Lysander, June 02, 2007, 02:25:25 PM
Lysander
Hi guys
I am new here. I have been playing electric guitar for about 2 years and I wanna buy  a pickup now. I have an U.S.A. built Fender Stratocaster with 3 single-coil pickups and I am thinking about replacing the bridge pickup with a BK pickup (there is plenty of space in there).
 Heavy metal is what I want to play, I'd love to have a sound like ''Into the Void'' of Black Sabbath ''Metal Gods'' of Judas Priest or ''Suicide Solution'' of Ozzy, generally 70's and 80's stuff. Basically I like the middle frequences boosted and I DONT like an electric/trebly sound.
I use a 40 Watt tube amplifier, a Traynor one. Wich pickup should I get to sound heavier?
Thanks
Crazy_Joe
Here.... is....the. PAINKILLER!
Yeah Painkiller i just got a calibrated set for my Explorer and have been playing heavy riffs all day!
Black Dogs
for a strat i'd go with warpig or holy diver
Crazy_Joe
Warpig i think would be a bit overkill for what he wants. I agree with Holy Diver though that could be an option.
Black Dogs
Tarzan
You would need a new scratchplate - But I can't see why it shouldn't fit in the cavity.
Lysander
Quote from: Tarzanwill a humbucker fit?
Yes, I removed the pickguard and there is space enough for a humbucker in the bridge position.
I'd like a dirty, middle boosted sound for solos. but as I said, not an electric, thin, trebly sound. Something ''fat'' and heavy.
I like to palm-mute when soloing, especially in the low strings and that needs a fat sound to work.
Miracle Man Matt
Ive seriously thought of doing this...
get a set of Uber sinner single coils, there is a clip on the players section and they sound AMAZING!!!  perfect for what u want and, imagine the look on peoples faces, when they see a 'standard' stat soundling like a war machine!
Im sorry to be persistant...but I'm on a mission to build the most badass guitar of all time.
Lysander
Ok, I'll think of what you guys say, but when I tried to order a Warping pickup, several options I hade to chose confused me a bit:
Spacing: 50mm or 53mm
What does this mean? How do I know if my guitar is 53mm or 53 mm?
Should I open the cover?
:x shite I just changed strings!
Thanks again
Transcend
Quote from: LysanderOk, I'll think of what you guys say, but when I tried to order a Warping pickup, several options I hade to chose confused me a bit:
:x shitee I just changed strings!
Thanks again
the difference spacing measurements are for if you have a floyd or not and only applies to the bridge pickup
i cant remember which is which though,,,,......
If you can fit a humbucker in the bridge, I would go with a Holydiver, Cold Sweat, or Rebel Yell. If you can only use single coils then a Sinner/Trilogy Suite set would work great as well.
gingataff
Thanks again
Use a ruler to measure from E string to e string over your bridge pickup.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Lysander
Quote from: gingataff
OK, thanks it seems to be over 5 cm, must be 53mm.
What if I get a Floyd-Rose? I am planning to get one, can I do it if I have a 53mm spacing, or only if I have a 5mm?
Lysander
By the way, I think I'll get the Warpig. From what I read in the specifications it must be ok for the stuff I wanna play.
Tarzan
Floyd Rose spacing is 53mm, so you will be fine.
