Author Topic: Metallica/ Rebel Yells / Diezel  (Read 7032 times)
« on: June 16, 2007, 02:58:57 PM »
Someone asked to make a cranked clip with the Einstein, so here it is.
Well, this is Master around 08:30, which is cranked if you ask my neighbours :?
Playing a bit sloppy and well the original solo is just too quick for me ole man  :(
One take except for the clean bit at the end, I had to switch in the chorus which required a second take, but no change of settings, just the mode.
All played in Mode3 on Channel 1 except the clean which is Mode1 Ch1.
« Reply #1 on: June 16, 2007, 03:00:43 PM »
Ohhh and here is another clip taken with the Diezel on the same settings as above but instead on Mode2 Ch1 and on the Lead Channel. Played on a Gibson LP Special with BKP-P91/92:
http://www.thegutbusters.com/temp/whiteroom.mp3
Muso
« Reply #2 on: June 16, 2007, 10:22:59 PM »
hey thats hitting the tone nail pretty much on the head, I really like my rebel yell how would that amp of yours handle a Dokken or White Lion tone?
« Reply #3 on: June 17, 2007, 09:02:45 AM »
Quote from: Muso
a little less bass and more treble, that would be pretty much it then, right?
There is lots of EQ range left allpotis were around noon. But better for those is a cranked and boosted Marshall for sure.
« Reply #4 on: June 17, 2007, 03:43:36 PM »
that clip owns! the einstein does seem to get a lot better as it gets louder. YU've just about nailed metallica with a lil combo : :)
« Reply #5 on: June 17, 2007, 04:44:29 PM »
Quote from: indysmith
Thanks, well "nailed Metallica" would require minimum doubled tracks per guitar, also maybe less mids and ehem, some practise ... but I liked the way it felt to play with this a bit less tight setting.
By the way, it is not the combo. Combo is 50W, has reverb and a slightly different voicing. I own the 100W head (more fun as you can mix pairs of different power tubes) and play it through a ported 2x12.
Diezels are quite special and not as easy to dial in as other amps, the EQ is very extreme (compared to a Marshall or also my Bogner, which are more subtle). You should give the amp a try if you can.
I compared it to many other amps in the shop (Marshall VM, Orange RV, HOOK, Mesa, Soldano Avenger). I preferred the Avengers lead sound, but it lacked the loop and channel switching options of the Diezel.
WITH FULL DISTORTION
« Reply #6 on: June 18, 2007, 01:01:45 AM »
itīs simple a perfect distortion
ahahahahahah UNHOLY stuff. excellent crunchy.
JP
lifted
« Reply #7 on: June 18, 2007, 04:31:09 AM »
great playing and tone, again, indeed.   What kinda wah you got going there?                 Lifted
Irish Tour/ Mule Set,    Apache Set... in Strats .... Nailbomb Bridge,Cold Sweat Neck in Ibanez S540
JamesHealey
« Reply #8 on: June 21, 2007, 04:55:16 PM »
sounding better hunter, it's now going from absolute turd to pretty damn nice sounding...
Turn it up louder you little slut! screw your neighbours I wanna hear that thing on atleast half volume!
« Reply #9 on: June 21, 2007, 09:13:50 PM »
Quote from: lifted
Teese RMC3 with the "Picture This" (Picture Wah) setting
Mr Ed
« Reply #10 on: July 04, 2007, 03:18:08 PM »
Sexy!
