Author Topic: how to tell what pot's I have on my sg  (Read 5888 times)
  • Truly bad since 1972
« on: June 18, 2007, 04:47:03 PM »
Is the a way of testing(can't see numbers on them) with a meter if so what setting etc...thanks
« Reply #1 on: June 18, 2007, 06:00:04 PM »
I'm 97.89 percent shure they're 500k.
« Reply #2 on: June 18, 2007, 07:40:18 PM »
you can measure them across pin 1 and pin 2 when turned down, they'll usually either show 250 or 500 KO
Normally it should be printed on the pot as well.
« Reply #3 on: June 18, 2007, 07:42:59 PM »
so what to set on tester..and this ain't no ordinary sg was the dodgy 90's one that originally had Blawence pickups
Metal-Assmoney
« Reply #4 on: June 24, 2007, 01:14:58 PM »
pots are really cheap, id just as soon switch em out. then you know what you have and you know they are brand new
« Reply #5 on: June 24, 2007, 03:11:40 PM »
Quote from: sgmypod
set it to a value that you can read between 200 and 600 KOhm, value should be either 250 , 300 or 500 I guess
« Reply #6 on: June 24, 2007, 11:52:15 PM »
You can't test the volume pots with the pickups attached by the way, you won't get a reading.  Tone pots are OK to test all wired up though.
« Reply #7 on: June 25, 2007, 09:05:26 PM »
might just swap out, these are 90's the ones that had bill lawrence pickups(labeled gibson, had a pcb board on them ahh, now been rewired and other guitar) so prob cr@p anyways...recomendations for pots etc..twinfan
« Reply #8 on: June 27, 2007, 08:45:08 PM »
CTS full size pots, short shaft, should do you right matey  ;)
I get mine from WD Music.
« Reply #9 on: June 27, 2007, 08:56:11 PM »
500k ones.?..what caps
« Reply #10 on: June 27, 2007, 09:28:58 PM »
500k pots.
Caps?  0.022uf Orange Drops are OK, or Hovland MusiCaps if you want to splash out.  I've got some old random ones from AxesRUs which seem pretty good too.
