Author Topic: Old amps - wear out and lose volume?  (Read 3551 times)
« on: June 22, 2007, 09:08:47 AM »
I got the chance to crank one of my 100w Klipps at rehearsal last night - killer overdrive   :twisted:
However, the volume wasn't really that loud even using Vintage 30s.  I can get it much louder by using a booster pedal up front - not just more gain but significantly louder.
I'm guessing the amp's components have sagged/worn over the years of (ab)use and it's not as efficient as it used to be?  And that boosting the front end with a pedal compensates for the signal loss as it goes through the amp?
  • Truly bad since 1972
« Reply #1 on: June 22, 2007, 09:31:26 AM »
would get that serviced may be something small
« Reply #2 on: June 22, 2007, 09:56:18 AM »
My other Klipp head is exactly the same though - this is why I'm thinking it's an age thing...
« Reply #3 on: June 22, 2007, 09:57:11 AM »
you have two..why doesn't that supprise me....still may be able to be fixed
« Reply #4 on: June 22, 2007, 10:00:06 AM »
I have three - two 100w heads and a 60w...
« Reply #5 on: June 22, 2007, 10:01:14 AM »
damn you must have a good job
« Reply #6 on: June 22, 2007, 10:10:55 AM »
I don't know about worn components, most caps/resistors in those old Laneys are perfectly ok - some amps just ain't that loud and it's natural for a booster to get them much louder (specially if it's the one I sent you, lmao)  :lol:
Old/worn output valves will cause loss of volume/punch so it may be worth looking into that but I doubt all three amps are on the quiet side because of worn components.
 :twisted:
« Reply #7 on: June 22, 2007, 11:08:05 AM »
Cheers HTH - and yes, I was talking about your booster  :twisted:
The 60w is very loud and is almost like a switch with the volume.  The 100w are more progressive.  I've had one of the heads checked when a valve seat went AWOL and they didn't say there was a problem with it.
Must just be a character thing I guess.
JamesHealey
« Reply #8 on: June 22, 2007, 11:23:46 AM »
caps loose their balls after years of use it might be worth getting it all re-capped and serviced/tubed up...
It'll make a difference.
futuregun
    • http://www.myspace.com/zombie_the_hero
amp aging
« Reply #9 on: June 22, 2007, 11:44:24 AM »
ive got an original flextone form line6 ( yes boo and hiss all you want but im pooor :D )  and it used to be able to deliver decent(ish) crunch but now it is sevrely lackin.
i think a engl screamer is callin me as theres no point gettin that flextone fixed unless its you know "fixed" with a hammer and a gallon of deisel!!!  :twisted:
****chugachug chug Beeeuunneeuuhhhh... wwwaaaannnnoooouunnnnnn****
« Reply #10 on: June 22, 2007, 12:03:52 PM »
^ :lol:
« Reply #11 on: June 22, 2007, 05:26:59 PM »
Quote from: JamesHealey
the electrolytic ones do - don't let some noob rip out all the caps in the main signal path and kill the amp's tone.
 :twisted:
« Reply #12 on: June 22, 2007, 11:04:08 PM »
Don't worry matey - no-ones touching the amp until something breaks!
