wiring diagrams or help Holy diver bridge
Started by splawnster, June 29, 2007, 05:18:54 PM
splawnster
wiring to a single volume pot he white and green are soldered together,  the black goes to the pot post and the red and bare to ground
Or is should it be like a seymour duncan red and whit together black to post and green and bare to ground.
ESP LTD HM300 - Holydiver ::::::       Kramer stagemaster I -   Crawler ::::::
ESP custom M-1 -VHII
There should have been a wiring diagram included with the pickup. I know that BK does not use SD's wiring scheme, but I don't know what it is, as I have someone else do my wiring for me. PDT_008
splawnster
I found this
What is the Bare Knuckle Four conductor colour code?
Black =start of screw coil
White = finish of screw coil
Red = start of slug coil
Green = finish of slug coil
For standard series operation solder the red to the pot tag, the black to ground(usually the back of the pot casing) and solder the green and white together.
splawnster
Found the wire diagram that came with the pickup. white and green together, red to volume post  and black and bare to ground. I'll post my thoughts of the HD later.
