Reduction in volume of amp
Started by TomW, July 01, 2007, 09:15:54 PM
TomW
Every so often I've been noticing that my amp suddenly goes quiet for a couple of seconds and then returns to normal volume. Is this a sign that the tubes need changing or is there something wrong with my amp?
Riff Raff/Stormy Monday, Holydiver and Mississippi Queen!!!
www.myspace.com/therealamorist
Metal-Assmoney
hmm, it could be a number of things. the only way to really tell these things is to try and isolate the problem. i can give you a few steps to try and find the problem. if you do these in order you may be able to isolate where it is.
1) Check all the wiring in your guitar. jam a different amp for a few hours.
2) Try a different cable.
3) plug the line out of your amp into a computer and play for a bit. if the problem is still there, then the problem is in or before your preamp stages. if its not, the problem is in your power stages.
4) different speaker cable to the cab.
CUBE
try changing your power tubes
stay disembodied
BKP's so far nailbomb 7 , nailbomb 7 neck.
Metal-Assmoney
that can be expensive, and its a shot in the dark. he should really try to isolate what the problem is before taking a stab at it.
CUBE
your right.. whats a set of tubes cost like 60 bucks.
its does not sound like cables.
 i bet its a class A/B amp and when the push /pull happens its whats dropping the volume.
stay disembodied
Metal-Assmoney
does your amp have a rectifier tube?
my minimat does that if you have it on a ridiculously low volume. Try cranking it a bit? lol
volume fluctuations are one of the symptoms of output stage valves about to give it up - how long you had those valves in the amp?
one of the more common volume related problems occurs with effects loops - try plugging a patch cable between the send and return jacks when the volume fluctuates and see if that helps.
lastly, it could be dirty volume pots - just try rotating the pots a dozen or so times around the range you tend to have it set at.
:twisted:
TomW
I've tested all of the cables etc and they seem to be working fine so I think it probably is the tubes as they have never been changed and I've had the amp about a year now.
Anyone know of a good place to order tubes from? Are www.eurotubes.com any good or is there somewhere better?
Thanks for the help :)
Woogie
Metal-Assmoney
JJs from eurotubes are the best bang for the buck. i run em in my AT-100 and they kick ass, and with 12 tubes the retube only ran me like 150 bucks. from groove tubes it would have cost me $300.
