Author Topic: loose studs  (Read 4928 times)
loose studs
« on: July 02, 2007, 11:28:26 AM »
i'm upgrading the bridge on one of my guitars.
the problem is the new studs are a shade less wide than the old ones - and they slip very easily in the old holes.
what would be the solution to this problem?
i was thinking of supergluing the new studs in - but it feels like a bodge.
would the right solution be to fill the old holes with doweling and rebore slightly smaller? that sounds like a job for an experienced luthier
Metal-Assmoney
loose studs
« Reply #1 on: July 02, 2007, 11:32:02 AM »
actually, a good solution to that would be to buy some wood filler and kind of coat the edges of the holes lightly and then let it dry
loose studs
« Reply #2 on: July 02, 2007, 11:38:15 AM »
I would plug and redrill  if there was more than a mm difference.  I would super glue or epoxy it if was less - epoxy will fill any gaps better.  Makes it damn hard to get them out again though so dont use to much - a little goes a long way
depending on the gap and the type of stud  and the value of the guitar i might be tempted to shim the hole with a bit of veneer just to make it a tight fit.  This works better if the post has a lip at the top that will cover up the fix.
loose studs
« Reply #3 on: July 02, 2007, 05:38:47 PM »
Quote from: Metal-Assmoney
Wood filler doesnt really have any structural strength - if i was going to use a filler i would mix epoxy with wood dust to make my own high strength filler
Metal-Assmoney
loose studs
« Reply #4 on: July 02, 2007, 10:48:00 PM »
naturally i do that, its been so long since i had to use it i totally spaced it out.
loose studs
« Reply #5 on: July 03, 2007, 10:14:54 AM »
the studs touch the edge of the hole - but dont grip. i'll buy some epoxy on the way home tonight.
thanks once more wezv!
G
loose studs
« Reply #6 on: July 03, 2007, 10:28:28 AM »
if there was a bridge wire dont foget to re attach it before gluing the post in place
sounds daft but its always worth pointing out!!
