Author Topic: 7 String Pickup Question  (Read 3333 times)
metalfiend666
« on: July 02, 2007, 03:25:35 PM »
I'm looking for some pickups with a twist for my soon to arrive Ibanez Universe. I already own a Universe, so I know I dislike the Blaze bridge, the single coil is cr@p, but the Blaze neck is good. I'm pretty much set on an alnico Nailbomb for the bridge, but I’m after suggestions for the middle and neck.
I’ve been told that BKP offer 7 string singlecoils, but the customer has to supply the bobbin. What I’m hoping to do is get my existing Blaze single rewound to something much nicer and then have a special pickup made for the neck slot consisting of a singlecoil and a dummy bobbin so it’ll fit the existing route and pickguard. I’m guessing winding only one coil of a humbucker shouldn’t be a problem.
So, what spec should I ask for? I want a nice versatile set that can cope with metal (as if you couldn’t guess), but a bit of everything else too. I’ve been messing around with a lot of bluesy “in between” position stuff using the singlecoil neck and middle of my RG 6 string, which is why I want a 7 string with neck and middle singlecoils. The 6 strings not going to be around for much longer.
I prefer the sound of alnico magnets over ceramic and I’m currently running though an Ashdown Fallen Angel 60 running JJ E34L’s into a Trace Elliot 3x12 (yes, three). I like the sound of a Duncan JB-7/59-7 combo in mahogany too.
« Reply #1 on: July 02, 2007, 03:34:42 PM »
Probably makes more sene to get a normal neck humbucker and have a coil split switch as well.  either way it will never sound exactly like a single coil because magnets are in different places and coils are different sizes - - but if you speak to tim, he might be able to tell you different
« Reply #2 on: July 02, 2007, 03:59:39 PM »
metalfiend - Are you by any chance a mod on 7strings.org in a doom metal band that wear scrubs covered in blood on stage?
metalfiend666
« Reply #3 on: July 02, 2007, 04:59:54 PM »
Quote from: WezV
I wonder if it's possible to make a singlecoil without mounting tabs and mount it on a humbucker bottom plate? I really want a proper singlecoil sound, not a split humbucker sound.
« Reply #4 on: July 02, 2007, 05:01:42 PM »
if tim can do one with magnetic pole peices it will be a bit more like a single coil but its still gonna be smaller and sound different
makes sense to speak to tim
metalfiend666
« Reply #5 on: July 02, 2007, 05:02:24 PM »
Quote from: noodleplugerine
Yes, that be me, though I wouldn't describe Matron as a doom metal band. I've had to leave though, being in a band that rehearses Sunday afternoons in London isn't going to be good when my child's born.
It's sevenstring.org btw ;)
metalfiend666
« Reply #6 on: July 02, 2007, 05:05:27 PM »
Quote from: WezV
Sounds like I do need to give him a ring then.
Any suggestions on what pickups would work though?
« Reply #7 on: July 02, 2007, 07:52:14 PM »
Quote from: metalfiend666
Saw a Matron gig a while back - In all honesty recognized you straight away from the avatar :p
... Recognised the name :p
