Author Topic: New Laney : Lionheart  (Read 9250 times)
Hell Hound
« on: July 03, 2007, 09:07:10 PM »
In search for a low wattage head I was browsing the Laney website and came accross this:
    Power RMS   20 Watts
    Inputs 2x Jack, Hi & Lo
    Channels Clean & Drive
    Equalisation Passive Bass, Middle and Treble
    Bright Switch Yes
    Preamp Valves 3x 12ax7
    Output Valves 4x EL84
    Class Class A
    Reverb Yes
    Footswitch FS2 (Included)
    Speaker connections 3x Jacks
    FX Loop(s) Yes
    Impedance 4, 8 and 16 ohm
    Baffle Marine Grade Plywood
    Cabinet Design Marine Grade Plywood cabinet with retro banding strip, leather strap handle.
    Weight 17 Kg
    Dimensions (mm) 250 x 559 x 250
    Channel Controls Gain (Clean), Gain & Volume (Drive)
    Master Section Global EQ, Reverb and Tone controls[/list:u]
     Those looks nice, seems to be new, and from the samples seems to sound quite nice. 20w is my perfect power ratting to run it almost full blast on reharsal (like 7 on the master) I just wonder how it'll does metal with a good clean boost or OD :twisted:
    I always fancyed those low wattage vintage amps, ironicaly I'm somewhat of a metal head. Do you think it'll do the "vintage" high gain Opeth sound with an OD? Or should I be better of with an Orange Tiny Terror? (you know the toaster wich makes your wallpaper fall of the wall :lol: )
Simon D
« Reply #1 on: July 03, 2007, 09:18:55 PM »
Well, Opeth do use the all valve Laneys, albeit the slightly more modern ones. I think it'd probably get close, especially with a high quality OD pedal in front.
Oddly, although I've been a Laney user my entire playing career, in my search for a new amp they just aren't figuring at all. Dunno why.
Warpigs.
Davey
« Reply #2 on: July 03, 2007, 09:21:33 PM »
let me tell you something about this amp
AMAZING sound. afghan dave and me ran it through a couple of paces at the LGS. real rock machine. it can play jazz cleans (as again, afghan dave can atest to, since we spent way too long listening a jazz dude play through it) without a pinch, turn it up, you got paul gilbert in a box. put a drive in front and yea it will do opeth (as pretty much any modern laney will, to some extent), but only for recording. if you intend to play any mid and more sized gigs, forget it, it will run out of power. use a clean boost for solos too, preferably.
but for practice, recording, home and small pub gigs, it would do real good.
i really liked it.
now to the amp in a lunchbox.. COMPLETE ripoff. inferior construction, made in china, questionable components, not to mention the already mentioned lunch box cab. for that money you will be not just treated better, but will have a MILLION (and this is an uderstatement) times better product, if you buy the MatAmp Little Rock. for the same price you get TOP quality components, UK handmade and top customer service.
Hell Hound
« Reply #3 on: July 03, 2007, 09:34:05 PM »
Thx for the review, I'm totaly in love with the look and feature of this L20R. If it sounds as good as it seems I'm buying one, no hesitation. for the power problem, well, it won't be a problem. First I plan on using a 2x12" (still hesitating on a TT or an Earcandy) with G12 Century (wich I already have) wich are freakin loud (102Db sensitivity). Then if I ever need more power I could still run the thing miced through the PA.
Hell Hound
« Reply #4 on: July 03, 2007, 09:58:12 PM »
Anyone know where the Lionheart is made? England?
Simon D
« Reply #5 on: July 03, 2007, 10:04:56 PM »
My amp (a TF300) was Brit-made, but it's 8 years old now. Best guess would be British made, but with the number of Brit manufacturers having stuff built abroad now, hard to say for sure.
Warpigs.
LazyNinja
« Reply #6 on: July 03, 2007, 10:28:13 PM »
Quote from: Hell Hound
I think they are PTP hand wired in good ol' Birmingham.
Hell Hound
« Reply #7 on: July 03, 2007, 10:41:47 PM »
Those use gold plated PCB, it seems they're made in England with a hand stamped 'build number'. I'll mail them :)
« Reply #8 on: July 03, 2007, 10:56:31 PM »
Using those high sensitivity Celestion Century speakers will make that amp seem alot louder than 'only' 20w, I think it'll see you fine.
I also think that 20w is a very conservative power rating for a quad of EL84s too - maybe Laney are quoting clean output ???
 :twisted:
Hell Hound
« Reply #9 on: July 03, 2007, 11:00:47 PM »
it's a special design, basicaly you have 4x 5w single ended EL84 poweramps running in parralel. So you keep that single ended class A sound (I love that tone) but with more power. Superb idea!
Adam.M
    • http://www.healeyamps.co.uk
« Reply #10 on: July 04, 2007, 03:06:40 PM »
Dear god, for some reason i'd dissmissed these amp's, biggest mistake of my life....
I've just been listening to the clips on the laney website, it sounds like this machine can do just about every sound i've wanted, a decent clean tone, a qotsa-style crunch (track 4) a vai-style lead tone (track 3) and a big american crunch tone (track 2) AND at bedroom levels with only minor attenuation required...
...and their blue! a very bedroom friendly colour.
I'm going to guess they used the head version for the clips :) davey, is the tone/sound pretty close to what you heard at LGS?
So, how much? :D
LazyNinja
« Reply #11 on: July 04, 2007, 03:25:52 PM »
The 20W head is £450 new. Not bad imo especially as competitors like Marshall 2061x, Cornford etc are much more expensive.
I didn't know they had soundclips now they didn't have one last time I checked. Can't listen to it now but I'll have a listen later at home. Ive always been very curious about these amps.
Mr Ed
« Reply #12 on: July 04, 2007, 03:28:17 PM »
I know it's not important... but what a bloody stupid name. It reminds me so much of "Lisa Lionheart" from The Simpsons.
Sounds like an attempt to be overly English to me...
Davey
« Reply #13 on: July 04, 2007, 05:07:30 PM »
i remember it to be a bit crunchier... but i did test it with my charvel with a warpig/trilogy
Transcend
« Reply #14 on: July 04, 2007, 05:18:52 PM »
Quote from: Mr Ed
reminds me of squall lionheart off final fantasy VIII
