Author Topic: Creating a stack which ohms do i go for etc etc  (Read 3770 times)
MrPring
« on: July 04, 2007, 10:28:48 AM »
Right guys the title was a wee bit misleading there.
Basically ive never used a seperate head and cab/s.
Ive always been a combo guy.
I have 2 cabs that i want to combine to make a stack.
Both are 8 ohms.
On the back of my amp (an old jcm 800) i can select 4,8 or 16 ohms.
Im really after some advice on what to select.
The cab im using for the bottom only has one 1/4 inch socket on it whereas the one im using for the top half has 2 or 1 in and 1 out i think.
Anyways HELP!!!
 :D
Thanks
“You can't arrest me, I'm a rock star" Sid Vicious
Blackguard Flat 50s, Rebel Yells and P Bass.
« Reply #1 on: July 04, 2007, 10:52:01 AM »
Plug both cabs directly into the head.  I'm assuming you have two speaker out sockets here.  The cabs will then be running in parallel and you'll need to select 4ohms output.
Job done!
MrPring
« Reply #2 on: July 05, 2007, 10:22:25 AM »
great thanks mate
thats what confused me. I thought with 2 8ohm cabs i'd need to switch to 16ohms on the back of the amp!
« Reply #3 on: July 05, 2007, 10:45:42 AM »
Nope, they're wired in parallel so you half the overall impedance.
