Author Topic: Making a pickup louder with pots....  (Read 4005 times)
Transcend
« on: July 06, 2007, 03:45:11 PM »
is this possible?? like if i put a higher value volume pot for my neck pickup would i be able to get that bit extra volume.... because after a lot of thinking ive realised my neck pickup tone is exactly what i want from a neck pickup.,.. its just far too quiet compared to the miracle man.
« Reply #1 on: July 06, 2007, 04:11:31 PM »
try raising it then setting the MM so you have a volume match when switching between pickups - then use a bit more volume on the amp
changing the value of the volume pot will not increase the output of the guitar
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #2 on: July 06, 2007, 04:17:00 PM »
Make your pickup louder, go WITHOUT pots.
If you wire your pickup direct to the output jack it will be at it's loudest and brightest. Perhaps a compromise is a mini switch that will bypass the volume and tone to give you this option.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Transcend
« Reply #3 on: July 06, 2007, 05:03:02 PM »
ahh i will try altering the height of it.... i dont want to be adding switches etc to my guitar its already been abused enough lol
hmm would getting it rewound have any other drastic changes other than more definition?
« Reply #4 on: July 06, 2007, 06:13:56 PM »
no point rewinding it if you like the sound. also no point changing the neck pickup
... but...
Its gonna be hard to get the pickups to match if you have a MM in the bridge and something with way less power in the neck (compared to a MM neck pickup - because obviously neck pickups need less power than the bridge unit anyway)
thats why tim makes calibrated sets!!!
