Author Topic: Clean Boost/Over Drive Pedals  (Read 3795 times)
JamesHealey
« on: July 18, 2007, 09:46:13 AM »
Ok guys im wanting to push my Cornford Hurricane a bit harder, the basic tone of the amp is astonishingly good, it just needs a little help with the front end to keep up with the 80s guitar solos ;)
I really love the sound of this amp, so I don't want to colour the tone at all, it's tone is mind blowingly good.. so guys what u suggest?
Cheers  8)
« Reply #1 on: July 18, 2007, 09:49:11 AM »
my Fulltone fat boost couldn't be more transparent; It boosts with the level and the gain control simply adds even-order harmonics to fatten up the sound. There is a tone control - but if you are serious about transparency you can put it on "10" and it is bypassed.
« Reply #2 on: July 18, 2007, 10:27:40 AM »
Z.Vex Super Hard On (for more gain and oomph)
Electro-Harmonix LPB Linear Power Booster (cheap transparent booster)
DeanS
« Reply #3 on: July 18, 2007, 11:11:39 AM »
I have a Cornford Harly and use either a Route 66, BSM treble booster and an Xotic BB preamp. If I had to chose one it'd be the BB preamp- masses of gain available, virtually noisless, can be used as a clean boost and is very very transparent- it gives you MORE of the amps natural characteristics.
Check out Andy Timmons' comments
http://www.youtube.com/watch?v=SiW22O914Cg
Mothers Milk set, VHII
jordan
« Reply #4 on: July 18, 2007, 11:52:40 AM »
Any of the Xotic pedals will do what you're after.
The RC is quite a low-gain boost.
The AC is medium-gain overdrive.
The BB is more of a distortion pedal.
I have the AC Booster, and use it to boost my Rivera R55. The pedal is absolutely fantastic, and couldn't be more transparent.
Tellboy
Cornford Hurricane
« Reply #5 on: July 18, 2007, 12:41:23 PM »
I have a Hurricane and use an Xotic BB with it. Although it has the ability to add distortion it is very transparent at lower gain /high volume settings and can add 30db of clean boost plus +/- 15db bass/treble. I'm not a huge effects fan but I really like the Xotic pedals.
« Reply #6 on: July 18, 2007, 01:56:06 PM »
Fourth Feline
« Reply #7 on: July 18, 2007, 02:12:44 PM »
What comes to mind is a Barber 'Launch Pad'.
I do not yet own one, but according to Harmony Central, they seem to be described as more silent that the Zvex 'Super Hard on' which I first considered.
I also like the idea of a larger casing, separate + and - phase out - and the idea of it internally converting the 9v supply to 18volts to give more headroom within which to work.
I see they have some in stock at 'strings direct'.
Also, on :  forum.TPNgear.com
There is an interesting article in the 'Barber Shop' section( written by David Barber himself ) - about gain staging and "amp cooking".
I however would be using it on a clean amp to get more of the same but lifted by a few dB.
Regards,
F.F.
JamesHealey
« Reply #8 on: July 18, 2007, 04:03:03 PM »
got a "Digitech - Bad Monkey".. £40.
absolutely slays!  8)
What a great pedal for the money tried it against a DS1, TS9, ZW MXR..
Wasn't after anything ridiculously boutique i wanted something quite compressed and 80s tube screamer sounding, cover up that sloppy picking technique ;)
