Author Topic: Wiring  (Read 2520 times)
vrgnr08
Wiring
« on: July 23, 2007, 02:51:34 AM »
So. im gna order my Black Dog tomorrow and i want to make sure i get everything right. I know the spacing is 50mm now, but i dont know what to get for the wiring....Stock my guitar came with the pickups phased in the middle position on the pickup selector? The pickups were both Gibson Burstbuckers. I dont really care if the pickups are still phased or not. Im just wondering what wiring i need to get, or does it really matter? So 2 conductor or 4 conductor?
CaffeineJunkie
Wiring
« Reply #1 on: July 23, 2007, 03:23:50 AM »
4 conductor will give you more options, however, if you don't want to you don't need to wire it to have the extra options.
If you pick 2 conductor it does make it easier to wire the pickups, although you can't change your mind at a later date and install coil-splits etc.
vrgnr08
Wiring
« Reply #2 on: July 23, 2007, 03:44:15 AM »
so no matter which one i get. i will have a working bridge pickup?
CaffeineJunkie
Wiring
« Reply #3 on: July 23, 2007, 03:54:46 AM »
yup, doubt many companies would last if there products disabled the use of bridge pickups
CJ
Wiring
« Reply #4 on: July 23, 2007, 03:55:12 AM »
Quote from: vrgnr08
if you know how to install it...
ailean
Wiring
« Reply #5 on: July 23, 2007, 12:00:30 PM »
I got my BK pups with 4 conductor, fully intending to wire them in standard format for now. The pups came with instrauctions on how to wire them, it was my first attempt and it went fine (although i did burn my finger!).
From memory
Red wire to the switch
Black and bare wire to the pot casing (earth)
Green and white came joined together, just leave them alone.
Gibson LP std + Nailbomb set
