Sod it - reccomend me pickups (again lol)
Started by AngusYoung01, July 31, 2007, 08:37:05 PM
AngusYoung01
Riiight, change of plan again. I've foudn a guitar I'm hoping to get, its a Charvel HSS, and as I don't own a guitar with singlecoils, I'm quite lost for where to go, and the HSS sets the BKP do look pretty hot for the money!
Right, heres what I need:
- 80's Metal/ Hair Metal sounds, I play alot of Maiden, Metallica, Van Halen, Extreme, Bon Jovi, Def Leppard, Ozzy Osbourne, Vai, you know, the over the top big haired 80's metal!
- I'd like to be albe to easily coax out some great pinches from the humbucker, so obviously will need quite a hot PU.
-It'll be going through a Marshall DSL50, MXR Distortion+ (always on), Arion Chorus (Usually on), Crybaby, Phase 90, Boss DD3.
- It must clean up nicely too, I need some good clean sounds too!
- Must be pretty versatile, but mainly for the kind of sound I previously mentioned.
- I really want the neck SC to give me that Dave Murray neck sound, the lovely bubbly, smooth sound, and as I use alot of gain, I don't want it to sound muddy, OR sharp; like alot of SC's do. Basically I'd like it to be more on the humbucker sounding side  :wink:
Well, thats it I guess, please help, as it'll be my first time buying new pups, and I don't know where to look in the bkp department!
Quote from: AngusYoung01I really want the bridge SC to give me that Dave Murray bridge sound, the lovely bubbly, smooth sound
Err, Dave Murray usually uses his neck humbucker for solos...
For the bridge, a Holy Diver sounds right up your street.
lifted
ditto to twinfan on the murray,  but paired with the diver I would say Irish tours or trilogy for a little hotter, but my irish tours could hang with my Nailbomb and sound great clean
Irish Tour/ Mule Set,    Apache Set... in Strats .... Nailbomb Bridge,Cold Sweat Neck in Ibanez S540
AngusYoung01
SORRY! lol I did mean neck  :roll:
So ignore that and I'll change it  :wink:
AngusYoung01
So a Holy Diver with either Irish Tours or Trilogy :?:
Can the Holy Diver get out pinches quite easily? And is it pretty hot?
Also, do the SC's above sound mre like humbuckers, or will I need to get an EQ pedal :?:
AngusYoung01
Anyone? ^
ALSO I'm getting really pissed off, cus for some reason on this forum, I have to hit the Submit button loads of times before it does anything, everytime I hit it, it just keeps going back to the reply I'm posting  :evil:
So far, I've hit it 23 times for this single post!
I have the Holy Diver with a pair of Trilogy Suites.  I think this would be perfect for you.  With the Trilogies you can get a lot of drive from the neck pickup.
AngusYoung01
Quote from: PhilKingI have the Holy Diver with a pair of Trilogy Suites.  I think this would be perfect for you.  With the Trilogies you can get a lot of drive from the neck pickup.
Do they balance well?
'Cus Tim doesn't seel them as one of the HSS options?
Also, do they sound nice clean?
and thanks btw  :)
Doadman
What wood is your guitar made from?
Initially I would say that the HD and Trilogy Suites are an excellent combination for what you're after.
AngusYoung01
Quote from: DoadmanWhat wood is your guitar made from?
I'm not sure, probably alder or Basswood... theres not alot of information about it... its a Charvel 375 Deluxe?
They balance really well, I have them wired with the superswitch to give me one coil of the HB combined with the Tilogy in positions 2 and 4.  The guitar it is on is a superstrat with a swap ash body with flamed redwood veneer, maple neck with ebony fingerboard (scalloped from the 12th fret, a really beautiful job done by Feline).
AngusYoung01
Quote from: PhilKingThey balance really well, I have them wired with the superswitch to give me one coil of the HB combined with the Tilogy in positions 2 and 4.  The guitar it is on is a superstrat with a swap ash body with flamed redwood veneer, maple neck with ebony fingerboard (scalloped from the 12th fret, a really beautiful job done by Feline).
sounds lovely  :)  Pics?
And I think its got a switch that activates the HB in any position, so it could sound pretty cool.... I wonder if Tim would sell 2 Trilogys and a Holy Diver
deg0ey
I wrote a big long post yesterday about why you should get slowhands as your single coils to go with the HD, but then my PC froze and I couldn't be bothered to type it all again.
The basic idea is that they're darker than your standard single coils, and therefore sound smooth and clear at any gain level, while not having that harsh brightness you can get with some strat pickups.
I have them in my strat (see avatar) wired in series, so that you get a good neck humbucker-ish sound which matches very well with the HD.
AngusYoung01
Quote from: deg0eyI wrote a big long post yesterday about why you should get slowhands as your single coils to go with the HD, but then my PC froze and I couldn't be bothered to type it all again.
Ohh, cheers!
So now I only have three options  :lol:
Right, its either Slowhands, Trilogy Suite, or Irish Tours.... maybe I should email Tim?
AngusYoung01
I'm looking more towards the Irish Tours or the Trilogy Suite now... more than likely Irish Tours actually.... I don't know :(
Can the Holy Diver deliver some high output, for pinched harmonics and things?
