Author Topic: Pimp my geetars.  (Read 4091 times)
badgermark
  • Mm-hai!
Pimp my geetars.
« on: August 05, 2007, 03:55:24 PM »
So having decided to keep a hold of my SG and combining it with my Tele for a plethora of tones, I want to pimp them both out.
So suggestions for pimping needed people. The SG needs a new switch, keeps cutting out when I switch down to the bridge p/up. Also anything I can do to increase the usefulness of the volume and tone controls? Either full on or at 0, the in-betweens are pretty useless really.
Everything is stock, and before someone mentions upgrading the pickups, I neither have the money nor a good enough reason to right now. One day...
Pimp my geetars.
« Reply #1 on: August 05, 2007, 03:59:09 PM »
buy a few capacitors and pots to try and find one thats usits you best...  i would always invest in a nice quality nut as well to get the best tone from the guitars - cheap but effective
badgermark
  • Mm-hai!
Pimp my geetars.
« Reply #2 on: August 05, 2007, 08:20:15 PM »
Any pot or cap recommendations? Any easy guides out there to brush up on?
Pimp my geetars.
« Reply #3 on: August 05, 2007, 08:26:12 PM »
CTS pots are the standard.  If you've got a Japanese/Korean etc SG you'll need the smaller Alpha pots.
Caps - I've used Sprague Orange Drop and Hovland MusiCaps on my guitars, plus some old unbranded ones which are my personal favourite.  I believe the Jensen paper/oil ones are good too.
badgermark
  • Mm-hai!
Pimp my geetars.
« Reply #4 on: August 05, 2007, 08:34:25 PM »
USA SG, so I'll have a look around. Any good reliable sources for these pots n caps? Or will my local Maplins have a supply?
Pimp my geetars.
« Reply #5 on: August 05, 2007, 09:09:15 PM »
http://cgi.ebay.co.uk/Onboard-Clapton-esque-Mid-Boost-Circuit-OVERDRIVE-F05_W0QQitemZ180144430924QQihZ008QQcategoryZ41416QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
that looks interesting and weird. may or not be worth it, doesn't look like its going to cost much so could be worth a fiddle lol
Pimp my geetars.
« Reply #6 on: August 05, 2007, 09:20:28 PM »
Quote from: badgermark
I use WD Music for pots as they seem to have the higher quality CTS ones and you can get caps from Axes R Us.  The Hovlands I got from Wilmslow Audio.  A quick Google should find you all those guys  ;)
Ted
caps & pots
« Reply #7 on: August 05, 2007, 10:58:56 PM »
Or you can try specialty guitars for CTS and Hovlands. Might work out cheaper from the US.
www.specialtyguitars.com
Pimp my geetars.
« Reply #8 on: August 07, 2007, 06:50:46 PM »
Pimp your Tele with this:
www.eldoradostraps.com
