Author Topic: Fender Deluxe Reverb advice  (Read 12475 times)
Jp.
« Reply #15 on: August 22, 2007, 08:19:50 AM »
Quote from: HEAVIER THAN HELL
Quote from: Jp.
As soon as I saw this thread title I though "this sounds like a job for HTH" and loe and behold I open the thread and there he is. LOL
I havent seen anything from you in the Mashall modding arena for a while mate.....
Heh, I always try my best to help as there are so many hack-techs around and I hate to see people get ripped off for shoddy (or needless) work.
(to the original poster)... You ain't got much to work with only having two gain stages (one ECC83) available but you'll easily be able to have more gain, that's not a problem.  You're loosing lots of gain through the tonestack, so you could lift the ground connection on the 6k8 resistor in the normal channel tonestack for a quick and dirty mod for more gain.
 :twisted:
dude I was joking..... I was paying you a complement  :D
Mule, Irish Tour and Slowhands
Watsonica
« Reply #16 on: August 24, 2007, 07:17:15 AM »
I've had a lot of early Fender amps and a few of the Deluxes, really great amps. What I used to do back in the early 70's is take a very short RCA cord (RCA on each end) and plug it into the reverb in/out in the back, then the reverb control would act as a master allowing you to get some pretty good distortion at low volumes , later on someone actually started making a device called the "ice cube" that did the same thing.
Found this on the web..(below)..seems I'm not the only one who remembers it:
Quote
The original Ice Cube was a little ice cube shaped device that plugged into the
reverb input and output on Fender amps. It merely connected the input and
output jacks, there may have been a resistor in there. This converted the
reverb circuit into a cheesy harsh sounding overdrive. You can get the same
effect with a wire w/ 2 RCA jacks. There was a later version that allowed you
to switch between reverb and overdrive, and may have had some controls.
Of course I know your looking for more volume initially but this is something you might want to try just for grins.... :)
Oh..I should mention, I haven't done that in decades but it does work, as a precaution tho-before making the connection ?  Turn your volume down or your amp off- if memory serves it could make a loud enough noise to damage your speaker when connecting it.
AH!! I actually found one on Ebay>> Ice Cube II[/u][/color]
That "buy it now price" looks like a ^ rip-off to me unless you just bid low..but as I said it's easy to make one with a single wire.
I actually for some odd reason bought one of the later cubes but started getting back into Distortion boxes , it looked like this one>> Sustain coupler[/u][/color]
But believe me ..the prices were nothin like that back then (lol) ..so simple to make.
At the moment I'm in the same boat with you with my Marshall VS-8040 (less than 40 watts clean I think) wanting to get a louder clean sound with it but there doesn't seem to be a speaker situation or mod that I know of for it, so I usually just end up mic-ing it.
