Author Topic: Considering Scalloping my guitar..  (Read 7068 times)
AngusYoung01
    • Heaven Asunder
« on: August 30, 2007, 09:09:04 PM »
After playing a Jem, I liked that the last few frets were scalloped, so I may do this to my SG special.... but what would I do after scalloping, would I finish the board?
« Reply #1 on: August 30, 2007, 11:27:55 PM »
if you are goin to do it, do it to a cheap fender style guitar where you can easily replace the neck - strat style necks can be had real cheap
here is a tutorial
http://projectguitar.com/tut/scal1.htm
it uses a motorised sander but you can do the same with shaped sanding blocks.
i find 12-24 can be done with a couple of rattail files and a good clean up with sandpaper working through the grits after
« Reply #2 on: August 31, 2007, 06:13:24 AM »
Do it on a maple neck ... rosewood boards are a bitch to work across the grain of the wood.
« Reply #3 on: August 31, 2007, 09:37:06 AM »
i would disagree.  With maple you have the issues of refinishing and you also have the fact that maple if very unforgiving to shoddy workmanship.  You may be able to hide the odd amateur error on a rosewood board but no way will you on a maple board.
Another thing i would consider is not scalloping the whole fret, just scallop behind the fret.  Particulalry on the 1-10th frets where the extra width you are scalloping can lead to problems if you havnt done it before.  This will mean you can use the same two rat tail files for the whole board because the scallops will be the same size.  so, for a start its easier, and it will also allow you to still do a bit of chord work by fretting behind the scalloped section.  Doesnt quite look as cool though!
AngusYoung01
    • Heaven Asunder
« Reply #4 on: August 31, 2007, 10:06:24 AM »
I only have the one guitar, but I'm planning on scalloping the 19th fret upwards, maybe 18th, depends. Definitely not the whole fretboard!
I'll be using a rat tail file for the job, but will I need to refinish at all, as I'm not sure what finish has already been used on my board?
« Reply #5 on: August 31, 2007, 10:50:46 AM »
it really depends on teh quality of the board - if it seems a little dry after you have done all the finish sanding then use a bit of oil like lemon oil or soemthing hardening like danish oil
AngusYoung01
    • Heaven Asunder
« Reply #6 on: August 31, 2007, 11:32:50 AM »
Quote from: WezV
I regularly apply Dunlop Lemon Oil... will this mean I wont have to apply any varnish coating at all, if I just use the Lemon Oil?
« Reply #7 on: August 31, 2007, 11:35:40 AM »
Most fretboards have no finish on them when they leave the factory, nor do they need it unless it is a particularly dry freboard(other than maple and bubinga which regularly get lacquered)
AngusYoung01
    • Heaven Asunder
« Reply #8 on: August 31, 2007, 02:02:22 PM »
Thanks Wez :D
I'll get scalloping then!
