Author Topic: Keeley Java Boost  (Read 4098 times)
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
Keeley Java Boost
« on: September 02, 2007, 04:21:01 AM »
I am pondering on whether it is a good idea to buy a Keeley Java Boost?
I already own a Keeley Fuzz Head, which is phenominal, and I'm set on the Java Boost as THE treble booster, but it's a lot of money!!!
Do any of you people own one already? Have you had good times with it?
Is it as sexual as it looks in tone?
let me know about your hexperience' wid dis blue beauty!
Ben.
Bird
Keeley Java Boost
« Reply #1 on: September 02, 2007, 03:35:57 PM »
I've had one for a while now and love it. The 3-way toggle gives you 3 distict setting ranging from mild to that old Sabbath sound. I use it a lot as a boost with another distortion source. It's absolutely amazing.   :D
Gary
    • http://www.uploadedtheband.com
Keeley Java Boost
« Reply #2 on: September 02, 2007, 08:37:22 PM »
I was using one for a while with a Strat/ Hot Rod Deluxe. Personally I prefer the Zvex box of rock for a lead boost with that setup. I'm keeping it aside as it is clearly a quality pice of kit and I'm guessing it may work better with a darker guitar/ amp.
Bird
Keeley Java Boost
« Reply #3 on: September 02, 2007, 08:40:18 PM »
Quote from: Gary
The amp also has to be quite loud for it to give you the full effect. It's not a lower volume device and it states that in the instructions given. So unless your pushing the volume a bit don't expect killer tone.
 8)
Gary
Keeley Java Boost
« Reply #4 on: September 02, 2007, 08:44:18 PM »
The amp was cranked (10 - 11). It just made it a bit harsh sounding but I must stress that's the only guitar amp combination I've tried with it.
5F6-A
Keeley Java Boost
« Reply #5 on: September 02, 2007, 09:10:33 PM »
i like mine : lp + java +  trex alberta + keeley comp --> jtm45 plexi type amp
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
JJretroTONEGOD
Keeley Java Boost
« Reply #6 on: September 02, 2007, 11:26:56 PM »
Quote from: 5F6-A
mmh, nice setup! what is a trex alberta?
p.s as for the zvex it's a very nice pedal, I agree, I'll check it out if I can find a shop that stocks it. The Java has the three modes though! it seems more versitile, they are both good.
5F6-A
Keeley Java Boost
« Reply #7 on: September 03, 2007, 09:59:15 PM »
Quote from: JJretroTONEGOD
Quote from: 5F6-A
ibanez tubescreamer clone with a slightly less stout and cringy midrange. Made in Denmark.
