Quote from: sskintfor LP what would one use?
Why not take a ruler to your strings over the bridge pickup and measure from centre of high E to centre of Low E
If it is 50mm get a 50mm pickup
If it is 52-53mm then get a 53mm one
If you would NEVER want to coil tap or phase reverse a pickup (or parallel connect the coils) get the single conductor version, otherwise get the 4 conductor one
Most Gibsons only ever come with the single conductor to be fair though.
