For anyone that was interested - my Mockingbird re-paint.
Started by Nadz1lla, September 11, 2007, 09:31:56 AM
Nadz1lla
Hi guys, posted briefly about what I was doing to an old bronze series BC Rich Mockingbird in another part of the forum, but thought I'd post here more details as this is probably a more appropriate place, heh.
This is a run-up to actually making my own guitar at some point, I've done this little project just to see what finishing it is going to be like in my parent's garage environment. I don't have access to a spray booth or proper facilities, so as you can imagine I have a pretty dusty atmosphere to work in which makes the process a lot longer.
Basically what I am doing is I have taken my black Mockingbird (all black hardware also) and stripped it. I'm now painting it a really nice purple colour, the pic of the headstock doesn't do the colour justice, the light in the garage is awful, so I've found a sample on the net of the closest match:
All the hardware is being swapped for all gold hardware on it, and I'm putting a set of Gold covered Nailbombs in. I know it sounds a little silly putting new hardware and 'Bombs on a bronze series, but there is a method to my madness, the 'Bombs will be going on the Guitar I'll build later on out of some proper materials, and I'm thinking a Spalted or Bird-eye maple top for my creation.
Pic above is a sneak peek of the 'Bird, will post a full set of pics when it's complete.
As for the custom I'm going to be making...well, it's going to be very different... I've drawn out some design sketches for the body shape and it looks awesome on paper, just hope it's do-able, lol. But you'll have to wait for that, I'll just post little tasters during the build when I get around to it, hehe. :lol:
[url="https://heavyrepping.com/shop/store/arcanumplectra/"]https://heavyrepping.com/shop/store/arcanumplectra/[/url]
Nadz1lla
Ooh, almost forgot... Dunno if anyone else does little projects like this in dusty environments but wouldn't mind hearing how you combat the dust-in-paint situation. I've taken to using auto-glym! I guess it's kinda like T-Cut or something, slightly abrasive, you rub it on and it basically gets rid of the roughness and dust that has dried into the paint, and when you wipe it off it's pretty smooth after. What I'll be doing before and after the clear laquer coat has gone on, is Auto Glyming the whole guitar twice, just to get it as smooth as possible and then treating the whole thing to a coat of Meguiars auto wax, it's amazing stuff. Should get the axe up to a lovely show-room shine! :D
Not sure what to do about the dusty environment - I suppose you could try wetting the garage floor to stop the dust getting agitated when you move around?
Are you wet-sanding the guitar inbetween coats to keep the surfaces flat?  I'm not sure about using T-Cut or Auto-Glym between coats, it might leave the surface too smooth/shiny for the next coat to bond properly.  I'm no expert though...
ToneMonkey
I've got a full set of gold Gotoh parts at home (TOM, Stop piece, tuners, neck plate, jack plate 4 gold knobs all screws etc). Going cheap because I don't need it.
Nadz1lla
Ah I have the parts already, but thanks though!
As for the sanding between coats, yeah I am doing it just to get rid of uneven patches of paint etc. I'll prob just t-cut after the clear gloss is put on, didn't think about the surface issue, heh. For something that I'm just knocking up it's looking pretty good so far though. Pic above was without it being t-cut so the finish looks a little rough.
Nadz1lla
Quote from: ToneMonkeyI've got a full set of gold Gotoh parts at home (TOM, Stop piece, tuners, neck plate, jack plate 4 gold knobs all screws etc). Going cheap because I don't need it.
Actually if you still have it when I get around to making the Axe I'll be interested, but that's a way off yet. I'm skint so the wood is something I have to save up for.
Quote from: Philly QAre you wet-sanding the guitar inbetween coats to keep the surfaces flat?  I'm not sure about using T-Cut or Auto-Glym between coats, it might leave the surface too smooth/shiny for the next coat to bond properly.  I'm no expert though...
I would agree with that - but really you need to sort out the dusty enviroment first and unfortunately that means a lot of cleaning and hoovering
you dont really want to be applying any other products inbetween coats of lacquer - not if you want it to stick anyway.
once your workshop is nice and clean you need to spend as little time in it as possible in this situation.  Go in, spray a coat and get the hell out.  When i used to do my own spraying i had the guitars hung just inside my shed door - i could open the door and do all the work without going in and disturbing too much dust.  I also had a fan at the entrance to the doorway pointing outwards.   Not ideal at all but it should make do at a push
WIth spray cans you can get away with about 3 coats a day, and then you will need to let it cure for quite a while.  at least a month.  you can sand back the finish between coats but dont do it to often because you will sand through everytime - its better to build up a few coats then sand back - avoiding the edges.  Its so easy to sand through at the edges its better just to not sand them at all till right at the end
i think you might be having a problem with the overspray (all that paint thats floats in the air ahs to settle somewhere) from the can settling on the guitar, in that case i would have the guitar somewhere else when you spray it.  My sprayer has a cheap fabric wardrobe with a few extra air holes made in it that he hangs guitars in between coats - this means he can spray more stuff without worrying about the overspray getting on other guitars
Nadz1lla
Cool, cheers for the tips. I'm using proper laquer thinned down a little through a cheap airbrush, pretty good coverage. I do about 2 coats a day, 1 in the morning and 1 in late evening and the next day rub out any cr@p spots with a very fine sandpaper and a wipe over with a damp cloth followed by a soft dry towel before the next coat. I've messed up a little with some of the edges, like you say, it's easy to go through too far on the edges, but it's only on the back of the guitar so I'm not too worried about that at the moment.
Nadz1lla
Little update, body is almost done now. Might put one more clear coat on, not sure yet, but I'll be going to my parent's house tomorrow to check it over and decide on that. All going well, should be done by Friday hopefully!
I am pretty impressed with the cheap airbrush I bought to do this with, best £11.99 I ever spent, hehe. Gives a really nice coverage.
So here's the latest pic:
Nadz1lla
Woohoooo!!! Finally all done and my gorgeous gold Nailbombs are ready to decimate all!!!
I never noticed it before (when it was all black) but the neck pickup ring was always a little skewed, but now that it's 2 different colours you really notice it. A bronze series with all the hardware stripped off really shows why they call it "Bronze". The pre-drilled holes weren't measured out properly at all, and it looked pretty messy up close without hardware to cover up all the flaws. So now I've got all the hardware on you can really see where the neck pickup ring has been slanted by the poor hole position. I'm surprised it didn't look worse to be honest, but hey, it sounds amazing and that's the main thing, heh! :lol:
Kepu
Love the combination of purple and gold!
Now if only the guitar would've had quilted maple top and the purple finish transparent... :P
Metal is forever, but I still got the blues for you
Crazy_Joe
Black Dogs
I was really worried about what you were doing to that guitar when I saw the first post, but credit where credit's due, that looks sweet :)
Roo
