SG String Spacing
Started by AngusYoung01, September 13, 2007, 05:09:54 PM
AngusYoung01
Where do I measure it?
I've read about how some SG's have F-Spacing... so where exactly do I measure it?
bridge: string to string.
should be 50mm?
AngusYoung01
From the outside of the low E to outside of the high E, at the bridge, it measures 52...wtf
from inside strings - 50
the centre of the grooves in the bridge saddles?
centre of the string to centre of string?
AngusYoung01
well shouldn't the string be  sitting straight in the saddle groove?
AngusYoung01
Yeh they are... hmm... maybe I'll just order 50mm?
measure the centre of the polepiece to the centre of other polepiece on your current P up?
I guess Gibson's are usually 50mm
AngusYoung01
Its wierd  :?
Cus I've read some SG's and Exlorers are 53mm, this seems to g from 50-52.. so I'll maybe just stick to 50?
the_bleeding
i know! measure the spacing of the pickups instead of the strings! that should get it sure fire aligned.
Quote from: the_bleedingi know! measure the spacing of the pickups instead of the strings! that should get it sure fire aligned.
Quote from: Willmeasure the centre of the polepiece to the centre of other polepiece on your current P up?
:P what if its a blade
well, my local guitar tech said that it won't make too much difference anyway.
and if its not a custom job, i think Tim will do a swap in 14 days for cost of postage.
AngusYoung01
Right, the neck is definitely 50mm, the bridge seems wider  :)
BadMonkey
My SG is 52mm at the bridge & 50mm at the neck.
Gibson SG Standard: Riff Raffs & MQ
AngusYoung01
Quote from: BadMonkeyMy SG is 52mm at the bridge & 50mm at the neck.
Yup, seems to be that!
Doog
the neck is always 50mm regardless of the type of guitar because the strings get closer together as you get closer to the nut.
nailbomb & stormy monday; holydiver pair; cold sweat pair
