Pup set identification trouble
Started by miconmac, September 20, 2007, 01:56:19 AM
miconmac
Hi Tim !
I'd like to identify a set of BKP-90: a friend think he bought a set of BKP 90, but in fact the squares "91" and "92" are notched on the box.
Moreover, I notice the neck pup has more gain indeed than the bridge pup.
So I suspect my friend bought a "special" set with BKP92 for the neck and BKP91 for the bridge.
What do you think ?
Thks and keep rockin'
:wink:
TeleUS 1977 (BKBrownSugar), Dane D56, Dane DC12, Vox AC30 '69, DeluxeReverbII, OrangeHustler
fps_dean
I think the neck is probably supposed to be in the bridge.
miconmac
Each pup is identify as "neck" and as "bridge": my friend is absolutly sure to have installed the right pup at the right place :lol:
fps_dean
Are they set right?
If you fret at the 22nd (or highest fret) each pup should be about 2mm from the string.
You could lower the neck a little more if it's too loud...
