Author Topic: Tried a Power Scaled amp today...  (Read 7469 times)
« Reply #15 on: October 08, 2007, 06:37:06 PM »
The London Power website has a list of recommended installers:
http://www.londonpower.com/links.htm
No-one in London, but it may not be up to date.  Might be worth contacting them direct?
maverickf1jockey
« Reply #16 on: October 08, 2007, 08:40:09 PM »
^That's irony for you :wink:
« Reply #17 on: October 09, 2007, 08:19:36 AM »
Well after another testing session last night my Super Bass Klipp is in for Power Scaling.  It sounded awesome through my 4x12, but Stadium rock gig awesome.  There's no way I could use it at any of the venues I play at.
Should be done in a week or two, so I'll let you all know what I think of it...
« Reply #18 on: October 09, 2007, 10:00:25 PM »
Matamp have put power scaling in their amps before - I've seen amps they've made with a big 'ol variac on the front.
There are various ways to add power scaling to your amp - you can just scale the output section or scale the whole amp.  I'd have to look into it further to see the various options.  From what I've read it seems fairly involved.  I'll have to get Kevin's TUT installments and read up on his power scaling.
 :twisted:
« Reply #19 on: October 09, 2007, 10:08:24 PM »
Martin at Martamp is favouring scaling the power and phase invertor sections (using a PPIMV or Pre Phase-Invertor Master Volume) as this is where he's had the best results.  That's what is being done to my Super Bass Klipp.
opprobrium_9
« Reply #20 on: October 10, 2007, 02:19:44 PM »
dunno about the Black 'n Tan but i sure as hell want a pair of those Music Series Pro Headphones.  GODDAMN!  So expensive, but they look very tasty  :o
jpfamps
    • http://www.jpfamps.com
« Reply #21 on: October 10, 2007, 06:13:06 PM »
Actually the power scaling circuitry isn't at all complicated. It uses a simple high voltage MOSFET regulator for the B+ with an optional tracking bias supply for fixed bias amps so that the bias goes down as you reduce the B+ so that the amp maintains correct operation. The methods for doing this are fairly obvious and circuits are given in TUT2 and TUT5 (as part fo a project). TUT4 has a rather long and self serving chapter on power scaling which really doesn't give much more usefull info than that in TUT2 and TUT5.
The one problem with power scaling is that it uses solid state components that are more suitable for mounting ona PCB than hand wiring on tag strip etc, however these aren't insermountable problems.
Some manufactures have incorporated a variac into their design, however this only works if the filament supply is run off a separate transformer (and indeed any other supplies for channel switching etc). As the Variac + additional tranformer/s are quite bulky this method would be more difficult to retro fit to an exisiting amp.
Power Scaling is a trademark of London Power so you can't build and market an amp as Power Scaled without licience from London Power. However, my guess is that any patent of this technology would not stand up in court, so I suspect it won't be long before this type of control starts to appear on mainstream production amps.
  • Truly bad since 1972
« Reply #23 on: October 11, 2007, 03:52:29 PM »
nice amps..bet they cost a fortune..and then shipping
Rogo66
« Reply #24 on: October 12, 2007, 03:31:57 PM »
The Suhr Badger (18 watt) uses this also.  Here's a link to a demo of one:
http://www.youtube.com/watch?v=HBUxUB-6qjw&mode=related&search=
« Reply #25 on: October 12, 2007, 11:30:43 PM »
Quote from: sgmypod
about R$3200
£1.00 = R$3.80
so £850 + looooooong wait + expensive shipping  :lol:
