Author Topic: arrrr can't decide what string to get  (Read 1765 times)
JDC
« on: October 12, 2007, 05:45:01 PM »
I'm downtuned to C standard and use 11, 15, 18, 30w, 42w 56w
tension wise it's similar to 9-44 or 46 in E
can't decide over the plan steels though, should I get go for 11.5, 15 ,19 or not???
my style is more uber fast picking than legato but I wanna do some legato
might get a 32w instead of a 30w as well
ps my high C just went flying across the room!
« Reply #1 on: October 12, 2007, 07:58:48 PM »
I'm assuming you have a fixed bridge then? I had to plan my setup very very carefully to get "drop D" tuning in B (ie bottom A is my "E" string) with my floyd rose bridge!
I personally favour thicker gauge strings to get a decent amount of tension (provided the neck can cope in the tuning you decide on), and I also play mostly fast picking stuff. The odd quiet bit, but to be honest, I prefer tauter strings for that stuff too :)
I doubt this will help, but I live in hope!
Roo
« Reply #2 on: October 12, 2007, 09:25:36 PM »
Try them
JDC
« Reply #3 on: October 12, 2007, 10:30:01 PM »
kind of solved my own problem, got a floyd so the remaining strings were practically C# standard, so I fine tuned them to C# and the extra tension doesn't mess up bending and legato as i thought it might, hell I think i prefer the wounds with the extra tension, using my 3mm stubby instead of the 2mm it feels nicer to play on
