Replacing Speakers
Started by TomW, October 16, 2007, 06:06:03 PM
TomW
I have managed to get my hands on a cheap Celestion g12h and Im just wondering if it is ok to have 3 g12t-75's and one g12h in my cab untill i manage to save up for some more speakers, or will this damage my amp?
Thanks
Riff Raff/Stormy Monday, Holydiver and Mississippi Queen!!!
www.myspace.com/therealamorist
It won't damage your amp, but you always rate your cab by the speaker with the lowest power handling.  So with the G12H being a 30w speaker you've essentially got a 120w cab and wouldn't want to run a 100w amp much louder than half way to be safe.
:twisted:
TomW
What is a safe formula to work by?
I heard that a 50w head puts out 80w at max somewhere
its stating the obvious i know, but its a good idea to make sure all the speakers have the same impedance.
regarding power ratings, a 50w amp will push out more than 50w, but a 30w speaker will also handle more than 30w too (at least if we go by celestions ratings).
TomW
Well I managed to replace the speaker last night and it sounds good so far. Its abit fizzier than I expected but I'm guessing thats because its new and hasn't broken in yet, and I have only played through it at very low volumes.
I'm guessing that by using a hotplate I should be able to crank the amp more than half way without damaging the speaker. Is this correct?
kevincurtis
I would second checking the impedance matching, celestions website has some useful tips and links:
http://professional.celestion.com/guitar/features/drdecibel/index.asp
Quote from: TomWWell I managed to replace the speaker last night and it sounds good so far. Its abit fizzier than I expected but I'm guessing thats because its new and hasn't broken in yet, and I have only played through it at very low volumes.
Yep, it's not broken in.  Get it somewhere where you can crank it for a good hour or so.  That'll get rid of the majority of the fizziness.
Quote from: TomWI'm guessing that by using a hotplate I should be able to crank the amp more than half way without damaging the speaker. Is this correct?
Correct!
