Upper frets on Low E sound 'choked'
Started by indysmith, October 22, 2007, 01:53:29 PM
What could be causing this? they're not fretting out, the pickups aren't too close... I think it might be because of my ridiculously fat Beefy Slinky 11-54 strings in standard tuning... Too big to vibrate at such high frequency?
EDIT: just realised this should probably be in the 'tech' forums. oops, sorry about that.
_tom_ says his LP does it too...normal??
Elliot
I use 11-54s and I don't get the problem - so IMO its not the strings
ToneMonkey
Can you expand on the "not fretting out" bit and I'll have a think, I'm fairly handy at vibrating things  :lol:
Quote from: ToneMonkeyCan you expand on the "not fretting out" bit and I'll have a think, I'm fairly handy at vibrating things  :lol:
i mean that when it vibrates, it's not being choked by hitting frets farther up the neck, it happens even at the 22nd fret, with no obvious reason for it not to vibrate normally between that fret and the bridge. It even happens with a slide.
Oli
It's because there's such a mass of string trying to vibrate in such a small amount of space that makes it not sound how you'd expect it should- nothing wrong with your guitar, just physics!
Quote from: OliIt's because there's such a mass of string trying to vibrate in such a small amount of space that makes it not sound how you'd expect it should- nothing wrong with your guitar, just physics!
As i thought! Damn physics  :shock:   spoils everything.
Thanks mate
