Author Topic: Going back From active(Emg81) to passive(Warpig)  (Read 8130 times)
WITH FULL DISTORTION
« on: April 27, 2008, 01:26:43 PM »
Hails Guys
i received my bare knuckles and i want to install the Warpig in my Schecter Avenger
BUT, i completely forgot how to go back to passive in an all active electronics guitar
its loaded with a emg 81-85 set.
and it has a toggle switch
its a Schecter Avenger Model.
can you help me by telling how to install the warpig bridge on there? do you need pics?!?!?!
JP
« Reply #1 on: April 27, 2008, 02:08:58 PM »
so it has active pickups... but does it have active eq?
i suppose you want warpigs + passive eq?
if the schter has active pups + passive eq... then change the pots for 500k, and the capacitor for a .02uF.
Transcend
« Reply #2 on: April 28, 2008, 12:15:21 AM »
itll only have active pickups, you can use the electronics as they are
just remove the battery clip from the circuit
i believe thats right anyway.
« Reply #3 on: April 28, 2008, 09:07:48 AM »
Quote from: Transcend
No you cant - it will sound awful as the 25k volume and tone pots will suck the life out of the BKPs. (too low a value  when used with passive pickups acts as a load on the pickup and runs off all the treble leaving a dull sound)
If you have just a volume and tone , then do as gwEm suggested and get 2x 500K pots and the right capacitor and copy the wiring arrangement.
You can keep the switch and also the jack - just remove the black wire that goes to the battery clip
You will also want to put an earth wire from the back of the pot to the bridge unless the already had one left in there(this may be the tricky bit)
Transcend
« Reply #4 on: April 28, 2008, 02:31:09 PM »
Quote from: FELINEGUITARS
ah fair enough my bad.
« Reply #5 on: April 30, 2008, 08:43:19 PM »
$%&#ing Hails Unholy British Fellows
i didnt explain it properly
i kept all the original electronics from the schecter, but i had to cut some wire from various parts of the pots and/or jack.. to wire up other parts of otehr guitars
my main doubt was regarding the original EMG jack. cause i remember that its active right?!?!?
besides of that, i cant remember which one(i have another one, total=2 passive jacks laying down ) is the original one from the schecter,, but, since feline said i could use the emg jack, just having to cut the black wire.. i'll check
i have the original pots with the capacitor
what would happens if i wanted to use 2 capacitors??@@?
Q:p
ah, what about the EARTH wire? how to put it there?
thanks again
JP
hideous
« Reply #6 on: April 30, 2008, 11:44:42 PM »
Exactly.
If I remember correctly, when EMG's are installed, you never have a ground going to the tremolo claw/ bridge. Instructions even tell you to take the ground off if you are installing EMG's from a passive setup.
You will need it for passive pickups, otherwise guitar will buzz like hell.
Basically, you need to do exactly what FELINEGUITARS said - solder a ground wire from the volume pot casing, to the bridge. Body may not have a hole for this ground - if it came with EMG's as standard. Very difficult drilling may be required to make a hole for that wire. I wouldn't attempt that myself on a guitar I care about.
« Reply #7 on: May 01, 2008, 08:42:57 AM »
i think he said he took the original wiring out - so the guitar should have the hole for the ground wire even if the ground wire has been yanked out
on tune-o-matic bridges this means removing the bridge bushing from the body to put a new wire in... like jonathan says, its a tricky job if you havnt done it before - risks of damaging bridge posts and chipping the finish... probably worth taking it to a tech
oh, i love the shape of these guitars - reminds me i have a 60's teisco spectrum bass that needs rebuilding
« Reply #8 on: May 11, 2008, 06:46:32 PM »
yah
thats it
i just bought ANOTHER schecter AVENGER
and ...
http://www.instrumentosusados.com.br/fotos/R13018-02_2.jpg
here it is
i believe this one is mahogany
JP
« Reply #9 on: May 11, 2008, 07:55:38 PM »
funny, i just started ripping my old teisco bass apart today
see the similarity
and yes, before anyone says it... the bass is a mess and it was me that made it a mess.  Its the first bass i ever brought when i was 17.. it was a mess when i got it but its worse now!!!
« Reply #10 on: May 17, 2008, 07:05:30 PM »
AHAHAHAHAH TOTALLY CRAZY AND FUNNY
Q:)
hails
JP
IM PREPARING PICS
Q:P
