Author Topic: Mic for backing vox and guitar recording? SM58 or E835?  (Read 6673 times)
« on: December 21, 2008, 11:48:17 AM »
I'm thinking of having a dabble with backing vocals in my band, so I'm looking into mics.  Primarily for live use, I need something straightforward.  Our singer uses an SM58, and my DC singer swears by SM58s too so that was my first choice.  I read somewhere that ideally you should all use the same mic live as it helps with the mix - not sure if that's true though.
However.....
I may use it to record guitar parts as well from time to time, and I believe the SM58 isn't best suited to this.  Although I think if you remove the pop shield it can work OK.
Also, I like things that are a little bit different and my search led me to the Sennheiser E-835 which seems to be a good alternative to the '58 and a bit more flexible.  Anyone used one or care to comment?
So should I try the Sennheiser or just get the industry standard SM58?
« Last Edit: December 21, 2008, 11:50:18 AM by Twinfan »
nfe
Re: Mic for backing vox and guitar recording? SM58 or E835?
« Reply #1 on: December 21, 2008, 12:38:59 PM »
What kind of voice do you have? Or rather, how do you sing?
If it's gruffer rocky stuff then I quite like the Sennhiser e935's. If you're covering all bases then I like Audio Technica AE5400.
But, for a trusty, relatively cheap, workhorse mic, you really can't go wrong with SM58s.
rohlfo
« Reply #2 on: December 21, 2008, 12:42:34 PM »
same mics on stage does sometimes prove to be useful, espec. if you're cranking levels. The 58 is proven to be a brill, rugged, decent mic.... it's the safe card! I've seen E-835's in use, but can't remember what they were like...not that dissimilar I think. Both should give you a half decent amp recording as well.... obv. the SM57 is better for this, which you could use for B. vox without much hassle...I guess it depends where your priorities lie - singing or recording!
Crawlers, Riff Raffs
« Reply #3 on: December 21, 2008, 12:47:46 PM »
Vocals is the priority and I have a reasonably high voice, similar in frequency to Dave Grohl but not as high and I can't scream like him!  I sing fairly musically - I don't 'talk on pitch' like Mark Knopfler.
SM58 or 58A Beta seems like the way to go then?
« Reply #4 on: December 21, 2008, 03:53:44 PM »
... are you going to get two...?
rohlfo
« Reply #5 on: December 21, 2008, 04:15:28 PM »
V
I'd go 58....makes sense imo and same type as your singer - helps and looks cool  :D
Denim n Leather
« Reply #6 on: December 21, 2008, 04:23:22 PM »
You will want 2 mics, ultimately.
« Reply #7 on: December 21, 2008, 04:34:51 PM »
Yeah TO, I know I will  :)  Just trying to get one that will be OK at the moment  :)
Stock SM58 it is then.  Cheers guys!
mikeluke
« Reply #8 on: December 21, 2008, 10:11:01 PM »
Couple of thoughts:
If you are going to buy a Shure mic make sure you go to a reputable dealer - LOTS of fakes on eBay, some of which are very hard to tell from the real thing - Beta 58 is a better mic than the SM58 but does not have an on/off switch on the mic - you may/may not find this useful! I have both - I use the SM58 for practice and the Beta 58 for gigs.
Good luck!
Mike
Mules, Riff-Raff
Oli
« Reply #9 on: December 21, 2008, 10:27:26 PM »
Get the Sennheiser MD421... it's got an adjustable do-dad that sweeps from voice to music, and sounds great on guitar cabs, bass cabs, toms and kick drums, it's really versatile. I can't comment too much on the vocal side of it, but it was designed with that in mind, so it shouldn't be bad. It is a bit more pricey though, but worth it I feel.
Denim n Leather
« Reply #10 on: December 22, 2008, 02:53:39 AM »
I think it's worth getting 2 mics, each specialized for it's purpose. There's a reason why most people don't use a 58 for guitar, nor a 57 for vox, as a gross generalization.
« Reply #11 on: December 22, 2008, 02:37:15 PM »
denim'n'leather is right - 2 mics would be best. however i use a sm57 very often for vocals - i like the way i can shout into it and not get any ill effects, its quite tolerant of hard sounding Ts etc etc too.
« Reply #12 on: December 22, 2008, 03:15:46 PM »
I've read that if you remove the pop-shield from an SM58 you've essentially got an SM57 so the SM58 is the one I'll go for.  When I learn how to sing better, and work out what I don't like/don't like about the '58 I'll go mic shopping again  :)
« Reply #13 on: December 22, 2008, 04:26:58 PM »
Didn't Plant use a SM57 on TSRTS?
nfe
« Reply #14 on: December 22, 2008, 05:38:02 PM »
Couple of thoughts:
Good luck!
Mike
The SM58 doesn't have an on/off in any version...  :?Well, bar the radio mic  :lol:
As a general rule, on/off switches are a terrible idea on mics. Fastest way to silence yourself onstage by accident and easiest way to spike a PA when you can't work out why you're not getting a signal until...
