Author Topic: Wah wah  (Read 5897 times)
  • Truly bad since 1972
Wah wah
« on: March 26, 2009, 09:59:13 AM »
Am after a Wah wah..bit of a novice here not something I have used a lot, am after something fairly easy to use..not too mad..and not too expensive..please help
Re: Wah wah
« Reply #1 on: March 26, 2009, 10:13:07 AM »
A simple standard Crybaby is the obvious answer.
Antag
Re: Wah wah
« Reply #2 on: March 26, 2009, 10:16:34 AM »
The bog standard Dunlop Cry Baby (or one of its many variants) will do the job.  Personally I think the design has a few disadvantages: firstly, you have to depress the pedal fully down to click the siwtch & turn it on, so the wah starts from the "top" of the sweep.  Also, it's a bit top heavy - I've tipped them over when not glued to a pedal board before & they do get a bit crackly & wear out after a while...
But IMHO the Morley Bad Horsie is the best wah out there.  For starters it's switchless - the pedal is spring loaded in the "back" position.  You simply move it off the bottom & the wah turns on, take your foot off it & it goes back & turns off.  Also, it's whisper quiet, Morley typically put a wider, deeper sweep on them & they are built like tanks! :)
Re: Wah wah
« Reply #3 on: March 26, 2009, 10:18:45 AM »
I use a standard CryBaby live, and Martin uses a Bad Horsie.  As Antag and MDV say, they're the two main options with their own pros/cons.  I'd try one of those as a starting point  :)
Re: Wah wah
« Reply #4 on: March 26, 2009, 10:21:29 AM »
cool time to go make a fool of myself with a wah
Re: Wah wah
« Reply #5 on: March 26, 2009, 10:36:07 AM »
Oh, dont be such a crybaby
Re: Wah wah
« Reply #6 on: March 26, 2009, 10:37:24 AM »
I bought a Bad Horsie II and sold it almost immediately.
Only worked for me with high gain sounds - sounded terrible clean, to my ears.
I have a Colorsound, but I'm not sure that they're still made.  Crybaby would be the best bet.
Re: Wah wah
« Reply #7 on: March 26, 2009, 10:38:06 AM »
i use a crybaby from hell.
the morley spring loading looks aight. but id like to be able to take my foot off the wah and leave it on.
the crybaby has no led so you cant tell when its on. that can be an issue sometimes.
crybaby's aint bad and pretty cheap second hand.
CFH has the variable toe freq range, and variable heel freq range and the q control and a gain boost.
its pretty tech.
im waiting on a new wah though...... excited
Pete24v
Re: Wah wah
« Reply #8 on: March 26, 2009, 10:51:03 AM »
i recently lined Ed's pockets and bought the EVH wah, has a great vocal like midrange. The old George Dennis wahs are very good too, can be had for a good price on the bay.
Lew
Re: Wah wah
« Reply #9 on: March 26, 2009, 11:39:53 AM »
I played a new Vox Wah the other week and it was cack cack cack!!
dheim
  • DON'TPANIC!
Re: Wah wah
« Reply #10 on: March 26, 2009, 12:28:22 PM »
i've never had issues with my crybaby... i've got a jimi hendrix model (bought some 13 years ago) and i've always loved it!
too many? ;)
Re: Wah wah
« Reply #11 on: March 26, 2009, 12:44:00 PM »
my standard crybaby was tough.
i got a homebrew electronics medicine bawl wah, which looked and sounded cool.
but that got KICKED by someone running across the stage and it never worked reliably ever again.
If anyone has a broken standard crybaby id like to buy it. i just need the chassis!
my old crybaby chassis has a stripped out screw hole on the under side so one of the feet likes to fall out, and i have a chicago iron parachute kit coming which needs a crybaby chassis to fit in.
Re: Wah wah
« Reply #12 on: March 26, 2009, 01:13:50 PM »
Ok just seen the Artic wah apl-1 and the Apw-7 any ideas
http://www.axesrus.com/axestomp.htm
dheim
  • DON'TPANIC!
Re: Wah wah
« Reply #13 on: March 26, 2009, 01:34:44 PM »
why don't you simply glue the fault foot?
too many? ;)
Re: Wah wah
« Reply #14 on: March 26, 2009, 01:36:40 PM »
tried 2 today morley classic wah..although there is an easy ish way to get better results......and dunlop crybaby
 morley a bit too much and dunlop sucking tone like a bitch..and not quite enough
 dunlop not true bypass either I think
