Painkiller set capable of these cleans?
Started by G9, April 15, 2009, 06:00:50 AM
G9
Guitar's mahogany Ibanez S7320.
This is from my current Swamp Ash guitar, me playing a sloppy rendition of Rammstein's "Seemann" bassline. Pickups are stock, coil tap engaged, and settings are in the following order:
1. Neck, tone dial 10
2. Neck, tone dial 0
3. Bridge/Neck, tone dial 10
4. Bridge/Neck, tone dial 0
Amp is Line 6 Spider III 15, mic'd by Shure SM58 to TonePort UX2.  Settings have low mid and bass, high treble. Only effects turned is reverb.
Wondering if a Painkiller set, coil tapped, is capable of making these cleans. Granted, I'm using this guitar primarily for Rammstein-style Industrial Metal and Nevermorish material. Still, it'd be nice to have the cleans for those quiet moments. Again, forgive the playing. :oops:
Antag
IMHO you could get reasonably close to the neck sound.  Maybe not the exact tone but near enough in terms of feel & dynamics.  The PK neck is the only BKP ceramic neck pickup & the full humbucker is very punchy, powerful & "in yer face".  I find it quite a "hard" clean sound.  But coil-splitting gives you a decent useable clean tone.
Can't really comment on the mixed bridge/neck tones as I never coil-split the bridge & rarely use the middle selector position.
But here's an alternate suggestion: If you use the neck mainly for cleans (or to put it another way, if you don't need the neck for noodly high gain sweep-picking solos), then try a Cold Sweat neck (or even a VHII) with the PK bridge.  That gives you much more versatility...
G9
Well, Ill be attempting plenty of sweeps, legato, and tapping kind of in the Nevermore style. Thing that comes to mind is the "This Godless Endeavor" solo. Now Jeff Loomis uses EMG 707s in both neck and bridge, but that particular segment of the song sounds nice and fluid.
dheim
i've got a set of painkillers in an ibanes S470, and i love the neck pickup. almost obscenely.  :)
but i don't think you can really get that seemann tone with them, unless split, maybe... holy diver neck is closer, in my opinion.
playing was not so bad, after all!  :)
too many? ;)
G9
Quote from: dheim on April 15, 2009, 08:45:17 PM
Mmm... split as in engage one coil only? I never got the difference between tapping and splitting, and parallel and whatnot.
Haha, thank you. :)
ailean
Coil split is using 1 coil of a 'bucker (so similar to single coil). Tapping is taking the output from the coil part way through the winding, e.g. after 3500 winds of a 7000 wind pup (or something like that).
Gibson LP std + Nailbomb set
G9
Quote from: ailean on April 16, 2009, 06:23:15 AM
So I guess split is what I'm looking for.
So... anyone with experience concerning a split Painkiller?
Quote from: G9 on April 16, 2009, 11:10:48 PM
I have a split bridge.
I cant hear the clips though.
What do you want to know?
G9
Quote from: MDV on April 17, 2009, 12:03:15 PM
Mmm... I wanted to hear a split neck and a split neck/bridge.
Clip is attached to the first post, piano.mp3. I wanted to know if a split neck and split neck/bridge on a Painkiller set could make cleans as heard in the mp3.
And I cant hear the clip at the moment so I asked....
matters not, I'll listen when I get home.
G9
Quote from: MDV on April 17, 2009, 02:25:48 PM
Ah, apologies... here's mediafire if people are still having trouble.
No its cos I'm at work. (Slow day at work)
You'll just have to wait a few hours. (or for someone else with a split PK to come along)
G9
Quote from: MDV on April 17, 2009, 02:52:51 PM
Dear god, my lack of communicative understanding is appalling.
Alright.
dheim
ok, here i am.
and as usual i've overdone things a bit...
you've got:
PK bridge and neck doing an almost rammstein-unrelated arpeggio in full humbucker mode and almost split. almost because they're actually mixed with the middle humbucker, but the latter is so far from the strings that it works more or less like an hum-cancelling splitter.
too many? ;)
dheim
here is the same arpeggio in a mix with bass and synths, and finally what PKs do best...
too many? ;)
