Author Topic: Faded /flat finish's. How do you make yhem shine?  (Read 7383 times)
marantz1300
« on: May 17, 2009, 07:50:08 AM »
I just got a Gibson smartwood Exotic. How do I make the flat finish shine.The top is Peroba.
  • Brokeback is back
Re: Faded /flat finish's. How do you make yhem shine?
« Reply #1 on: May 17, 2009, 08:53:22 AM »
That's a very beautiful guitar. I don't know how to make it shine, but if it was my guitar I wouldn't change it. I like the look as it is.
« Reply #2 on: May 17, 2009, 12:14:55 PM »
No idea but nice guitar! Why change it?
« Reply #3 on: May 17, 2009, 01:15:13 PM »
As I mentioned in the other thread, you could just dive straight in with some T-Cut.
But I'm not sure (a) how thin the finish is (danger of rub-throughs) and (b) whether it'll turn out to be perfectly smooth if you polish it.
I agree with the guys, personally I'd leave it matt - then change the hardware to nickel to make it look less "furniture", more like a workhorse.
marantz1300
« Reply #4 on: May 17, 2009, 02:00:19 PM »
Thats what I'm aiming for.Like the Briggs.But that was polished.
« Reply #5 on: May 17, 2009, 02:36:10 PM »
Ohhh good plan!
« Reply #6 on: May 17, 2009, 03:15:50 PM »
Try polishing with T-Cut on an inconspicuous part of the guitar - maybe somewhere on the back, just a little bit to see how it looks.
If it looks bad, you can get the finish back to matt with some wire wool, micromesh or fine wet/dry paper.  If it turns out OK you can take the plunge and do the rest of it!
« Last Edit: May 17, 2009, 03:17:22 PM by Philly Q »
marantz1300
« Reply #7 on: May 17, 2009, 03:33:48 PM »
I'll  try a small area like under the pickup rings or under the switch ring.
« Reply #8 on: May 17, 2009, 11:21:00 PM »
i used t-cut on a faded finish V and it works well to give a shine... but be careful - its easy to get t-cut stuck in the grain, and it doesn't look good! looking back, i would try a different way to shine it
pagan7
« Reply #9 on: May 17, 2009, 11:48:24 PM »
Short of giving it a couple of coats of clear laquer for a glossy finish, then liberal amounts of any beeswax based furniture polish well buffed will make it shine more but I agree with Phily - leave it as it is and change the "bling" hardwear for something more workmanlike.
p.s. avoid silicon based polishes as they can give a hazing effect on some finishes
Tellboy
« Reply #10 on: May 18, 2009, 12:00:30 PM »
My PRS Standard has a similar satin finish. I found that by regularly using a good quality guitar polish (I use Gibson and give the guitar a good clean/shine everytime I change strings) the guitar finish will get much shinier. Also I went for the chrome covers when I fitted the calibrated Cold Sweats
« Last Edit: May 18, 2009, 12:11:30 PM by Tellboy »
marantz1300
« Reply #11 on: May 18, 2009, 05:20:41 PM »
That looks great. I'll buy some guitar polish .
