Dremeling a Trem area to bare wood
Started by Elliot, May 24, 2009, 07:34:47 PM
Hasnt Eric Johnson got his own signature brand of pedal batteries yet?
ToneMonkey
Yeah, they're yellow for a smoother output flow..... or that's what he says anyway.
gingataff
Quote from: ToneMonkey on May 28, 2009, 03:56:20 PM
Officially that's "Texas Rose Yellow" ;)
I see a rainbow rising
Look there on the horizon
And I'm coming home
would it not have been easier to put the blob back ;)
Quote from: ToneMonkey on May 28, 2009, 03:25:39 PM
Quote from: hunter on May 24, 2009, 10:06:27 PM
The neck pocket in my Tokai strat was always super tight, until I removed the finish, now it's a bit lose and I am really pissed about myself having removed the finish.
Ha ha, we've all had those moments.  How loose is it, something that could be fixed with thin vaneers?  You could pass it off as having done it on purpose then  :lol:
you need some 'no-more-nails', there's nothing that can't be fixed with that or blu-tack according to my missus  :lol:
maybe try something as simple as different gauge plectrums to shim the neck.
Quote from: HEAVIER THAN HELL on May 29, 2009, 11:59:43 PM
sounds like my alchoholic neighbour
i was building something in the garden that required two things to be stuck togther so decided to mix up a bit of super duper boat builders epoxy.  nieghbour comes out and says its just not good enough... i should be using no-more nails.
5 minutes later he comes out with a tube to prove a point - my epoxy had already dried like rock but he still wasnt having it.
