Author Topic: Dremeling a Trem area to bare wood  (Read 12673 times)
Elliot
« on: May 24, 2009, 07:34:47 PM »
Someone (of a bloke down the pub type of reliability) told me that if you remove the paint in  trem fitted guitars under the bridge plate you get better tone and sustain.  Now sounds possible, but also sounds like the idea of a theoriser rather practitioner.  Any one have any experience of this?
Re: Dremeling a Trem area to bare wood
« Reply #1 on: May 24, 2009, 08:08:11 PM »
Potentially "UTTER BOLLOCKS" :arrow:
A strat trem rests on the trem posts and is not affected by the paint if set up floating
I can see if he meant that the trem was flush against the body that you might get a whisker more coupling between the two , but hardly that you would notice, and certainly not worth removing finish for
If he had said in the neck pocket I would be more inclined to agree
Paint on a body does affect tone , but that can be in a positive way  rather than just taking away from the sound of the guitar.
I know that often a paint finish will take away a bit of excess top end and add a bit of weight to the bass end
I kind of factor it in to my builds
JustBecos
« Reply #2 on: May 24, 2009, 09:01:24 PM »
I have read something similar, though can't remember where now. That was with strat hardtail bridges not the trems though. Which would make more sense inline with what feline has said above, you might need to have Eric Johnson be be able to heard the difference.
Elliot
« Reply #3 on: May 24, 2009, 09:49:50 PM »
Many thanks for your replies, thought as much - it'll save me carving up my strat  :D
« Reply #4 on: May 24, 2009, 10:06:27 PM »
The neck pocket in my Tokai strat was always super tight, until I removed the finish, now it's a bit lose and I am really pissed about myself having removed the finish.
Matt77
« Reply #5 on: May 24, 2009, 10:10:26 PM »
Doesn't Eric Johnson does this and have it done on his sig model?
Am I getting the wrong end of the stick?
« Reply #6 on: May 24, 2009, 10:22:04 PM »
Doesn't look like it:
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #7 on: May 25, 2009, 02:28:41 PM »
EJ has the paint removed from the top of the metal block (not that many blocks have paint on to begin with) to get better contact with the underside of the trem plate.
I see a rainbow rising
Look there on the horizon
And I'm coming home
gingataff
« Reply #8 on: May 25, 2009, 02:32:27 PM »
I've wondered about this, wouldn't bare wood on the 'heel' of a bolt on neck give better transfer of vibrations? Or does having a smooth finish create a larger surface area and this is more preferable? Or is the difference so small that we would never have bothered to talk about this in the days before the internet?
And I'm coming home
« Reply #9 on: May 25, 2009, 02:51:36 PM »
That's the one.
chisa
« Reply #10 on: May 25, 2009, 06:52:38 PM »
yes he does, he does it to help with tuning stability
« Reply #11 on: May 25, 2009, 07:03:01 PM »
Why would removing paint under the bridge have any effect at all on tuning stability?  :?
« Reply #12 on: May 26, 2009, 01:43:39 AM »
+1
the internet effect again!
I'm sure EJ keeps these rumours going to reinforce people's opinion of him as an uber-guitarist
I'm not doubting his abilities - they are vast , but he sells himself well.
Same thing with Yngwie - even the being a bit of a dick - all adds to the reputation and keeps people talking about him.
It's the all news is good news sort of thing - like the Beckhams or Katie price keeping themselves on the front pages for very little reason but it all helps the brand (and the bank balance)
ToneMonkey
« Reply #13 on: May 28, 2009, 03:25:39 PM »
Ha ha, we've all had those moments.  How loose is it, something that could be fixed with thin vaneers?  You could pass it off as having done it on purpose then  :lol:
gingataff
« Reply #14 on: May 28, 2009, 03:42:26 PM »
I had a small blob of excess lacquer in the neck pocket of a Charvel, and when I removed it I found that the difference in angle meant that I then needed a fret dress  :(
And I'm coming home
