Started by slapnutz, November 07, 2009, 09:11:21 AM
Quote from: gingataff on November 08, 2009, 04:07:03 AMI'd suggest trying it with the pickups as is first of all, and see if that gives you the tone you'd like. If it's not quite right your luthier should be able to turn the magnet around easily enough, he won't even need to desolder anything.
Quote from: FELINEGUITARS on November 08, 2009, 11:39:10 AMIf you are happy to have inner coil of one pickup and outer of the other in this position then the magnet does not need to be reversed. This is also the case on the John Petrucci Musicman or Ibanez guitars
Quote from: gingataff on November 08, 2009, 11:59:09 AMQuote from: FELINEGUITARS on November 08, 2009, 11:39:10 AMIf you are happy to have inner coil of one pickup and outer of the other in this position then the magnet does not need to be reversed. This is also the case on the John Petrucci Musicman or Ibanez guitarsOf course Petrucci had his neck pickup installed backwards in his Ibanez models, you can see the screws are facing the bridge and slugs are next to the neck.
